| quasi |
Siemens Computer Grade Capacitors 100v 10,000uf. Part Number B41455-N9109-T made in Germany. I have 14 of them left.
Here's a piccy of 'em
Say $50 AUS each plus p&p.
Cheers |
| kilowattski |
| Are these the highly regarded LL grade electrolytic capacitors? |
| quasi |
I don't know.
The only data I have from a siemens selection guide (1990) is they are an increased reliabilty version suitable for demanding electronic power supplies.
They have a rated life of 110,000 hrs at 40 deg C.
I run 4 in my PA amp which is around 15 years old.
Cheers |
| enochRoot |
| are these from 1990 (date code)? also...what are the physical dimensions? |
| quasi |
Umm ...I'll check it.
Cheers |
| quasi |
The date code is 06.89.
The dimensions are;
diameter = 64.3mm
length = 107.5mm plus the screw terminals of about 6mm
Cheers |
| enochRoot |
| thanks for checking into that!! |
| kilowattski |
| Too steep for me....$38 USD for electrolytics that are already 15 years old is much too rich for my blood. |
| quasi |
That's my quandry...Brand new 15 year old capacitors.
I know (personally) they are fine and will last to their rated spec.
But they were indeed made 15 years ago. Maybe I'll use 'em ......quandry ...quandry .....
Cheers |
