| Dave Jones |
Care to give us a hint as to what it does? |
| hitsware |
| quote: | Originally posted by Dave Jones
After determining Fc (the freqency of the first order HP filter imposed by the baffle) one can take a chosen driver and (with a sealed box calculator (put the driver in an infinite baffle)), add the filter and thus approximate the system response................. |
| markp |
| A little more explaination would help. What are the columns and what is dia of? |
| hitsware |
| quote: | Originally posted by markp
space/1=in a tree
space/2=on the ground
space/4=on the ground near a wall
space/8=on the ground near a corner
height and width are the dimensions of a rectangular baffle
diameter is the diameter of a circle with the same area as the rectangle................. |
| Kittle |
What measurement units are you using?
inches? feet? cm? meters? |
| hitsware |
| quote: | Originally posted by Kittle
feet |
| markp |
| I think that there is more to it than that. The baffle can't just be converted to a round surface of uniform radius. The long axis will support lower freqs than the short axis etc.... |
| hitsware |
Intuitively I agree. However I have gleaned this approach from people who's knowledge I trust. Also it seems to be (empirically)
usable (within limits). A safer method would perhaps be to use the shortest dimension only (but perhaps too safe). This is in fact the same formula used to size the mouth of a horn. Obviously a mouth 1' x 9' is not going to act like a mouth 3' x 3', but perhaps if the ratio is kept reasonable all is well........... |
| Gregm |
At the Fb calculation you have a constant "565". How do you get that?
I'm trying to convert the functions into metres/centimetres |
| markp |
| quote: | Originally posted by Gregm
I'm trying to convert the functions into metres/centimetres | That unit is half the speed of sound per second in feet. |
| hitsware |
Try the new improved and simplified version
:smash:
http://home.comcast.net/~jhyamamoto/3ob3.xls |
