diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Help identifying capacitor - Click HERE for Original Thread
busman2
I want to replace some smd electrolytic capacitors in a preamp I own with smd film caps, but I can't identify this cap code. Anyone what can help please respond.
capacitor code on top.
470
6A
3F6
That is all that is on these caps. They are input caps for mic preamps. I want lower noise which the film caps will give. Please help if you can.
Thanks in advance.
johnnyx
All you can know from a surface mount electrolytic is the capacitance, 470uF in this case. The other codes are specific to the manufacturer. The working voltage is only sometimes indicated. The voltage can be estimated by physical size, in comparison to others of known value. You could compare the other codes to known ones in a similar fashion.
Surface mount ceramic caps have no markings whatsoever, so it could be worse.:)
Hope this helps.
busman2
Thanks that does help I was figuring that was the value for the first number also. :D
busman2
Well I identified it its a panasonic the first # is the UF rating the second (6) is the voltage and the (A) is the physical size code.
the last (3F6) is the lot#
Feels good to now be able to move farther into my project.
johnnyx
You've done better than I do. Where did you get the info? I would find it useful.
Page generated in 0.021034002304077 seconds with 16 queries,
spending 0.00668740 doing MySQL queries and 0.01434660 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
