diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
What is the simplest way, to convert this GC to a subamp? - Click HERE for Original Thread
Franz G
I am looking for the simplest idea, to convert this NIGC to a subamp:
- what is the easiest method to filter (lpf 100Hz), eg. use a buffer or not?
- what is the easiest method to mix both stereochannels?
Thanks for all ideas!
Franz
miguel2
In the Pass Labs diy site you find the articlle of el pipe-o with a filter to be connected to output of the main speakers amp.
Miguel
jackinnj
try this:
Franz G
Do I interpret this correctly?
This circuit is showing a crossover, mixing two channels and using two opamps (like OPA627).
So, I could bridge or paralleling the two output chips in this case.
Franz
carlosfm
That's right.
You sum the two channerls, then filter after that.
That way, you use half the parts because you don't need to apply filtering per channel.
On an already-made amp it's more practical to parallel.
EDIT:
Oh.:eek:
The summing op-amp has to be inverted.:bawling:
Franz G
quote:
Oh.
Could you explain this? I dont understand.
Franz
jackinnj
maybe we can dispense with the buffer, etc. in their entirety -- although I would hold my breath -- i haven't wired this up:
Franz G
3.83M for the feedback resistor?
No, remember the t-net! Too high resitance for a good feedback, nearby 4M!
I think, it is better to use dedicated opamps for filtering, when I look at this circuit!
Many thanks, jackinnj! I will try the first circuit, you showed in this thread.
Franz
carlosfm
quote:
quote:
Franz
Sorry, my confusion.
It can be inverting or non-inverting.
But with some requirements, if you don't want to have high DC-Offset.
Here is my sketch from when I made my sub.
I used an OPA2132 as input buffer and then an OPA4228.
Power amp is 2 // OPA549s.
Tube_Dude
Hi Carlos
You were right!! A inverting stage is better for summing two channels, because the summing point is a "virtual ground" and don't permit signal leakage from one channel to the other...
À nossa!!:drink:
carlosfm
quote:
Originally posted by Tube_Dude
Hi Carlos
À nossa!!:drink:
Hi Jorge!:cool:
Yes, I'm a little confused today, hard day at work.:xeye:
I've just connected the soldering iron, I will get better soon.:D
I actually used inverting summer on my sub, with an input NI buffer (it's not on my sketch).
À nossa. :drink:
Page generated in 0.028466939926147 seconds with 17 queries,
spending 0.00514197 doing MySQL queries and 0.02332497 doing PHP things.
Copyright ©1999-2009 diyAudio.com
