diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Lower cost transformer? - Click HERE for Original Thread
Papageoff
Please pardon my noobieness for asking this...
I am building my first amp, but it must be on a budget. I need something around 24VAC@7A and I am having a hard time finding a transformer for less than $80-$100us. Can anyone recomend something cheaper?
I am wide open on design... dual secondaries, single centaped, EI, touroid, etc. I just need to find one that will supply enough power to run a 60ish Watt stereo.
I have done a search that returned hundreds of results but many threads are very, very, looooong and wander off topic a bit. Any help would be much apreciatedIs that a word?
Nuuk
I'll leave this one for somebody living in the USA to finish voting and tell you where to buy a transformer.
But in the UK, which is usually more expensive than the USA, we can get a 160 VA transformer for around 32 USD!
uvellani
Try www.partsexpress.com - Search for 'toroidal'
http://www.partsexpress.com/webpage...oup_ID=605&SO=2
Apex Jr
I have a perfect transformer for you. Priced Right...
Signal EI core 220V input 48 Volt Center Tap and a
24 Volt Center tap at 7 Amps.. USING 115 Volt Input
will give you your 24 Volt Center Tap and also a
12 Volt Center Tap at the 7 Amps you need..
PRICE ON CLEARANCE at $ 7.95 ea have about 200
I do however have a $20.00 minimum order...
check my website www.apexjr.com for other items
Steve @ Apex Jr.
carlosfm
quote:
The last trafo I (custom) ordered was a 2x22V 528VA (12A:eek: ) dual secondaries toroid.
Cost was around 60 Euros, including transport by post office.
Lately I've been salvaging trafos.
Recycling is good for the environment.:D
FBsHT
So....
When you say 24VCT do you mean 24-0-24? As in two 24V windings.
Or do you mean 12-0-12. One 24V winding with a tap in the center?
Sorry if I'm being dense but I've seen both ways called 24VCT.
FB
Papageoff
Thanx! these prices are much better!
joensd
Another recent thread of many :
http://www.diyaudio.com/forums/show...t=&pagenumber=1
mateo88
Hey Steve, do those transformers have hum at all? Looks like a great deal!
dangus
Amateur Radio swap meets can be great sources of parts. I picked up some new-in-box Hammond transformers, and a broadcast grade audio transformer. for a couple of bucks each.
If you arrive towards the end of the day, hang around the garbage cans because a lot of guys will dump stuff rather than cart it home.
Apex Jr
These transformers came out of Harmon International
which is JBL, Infinity and others from one of there
discontinued amps and they do not have any hum as
far as I know. ........ Steve @ Apex Jr.
mateo88
Awesome, you'll probably be getting an order from me sometime soon. :)
falcott
Yes it is.
appreciate v. 1 value. 2 understand. 3 rise in value.
Papageoff
quote:
Originally posted by FBsHT
So....
FB
Yes.
random_id
Pardon my confusion...
I though a transformer rating of 24 VCT means that you can get +12, ground, and -12 from it (unrectified). So is it actually +24, 0, & -24?
If this is true, that would be a lot cheaper for me. I'm making a lot more gainclones. :cool:
Apex Jr
Transformer that 24 Vct is 12V - 0 - 12V
Steve @ Apex Jr
FBsHT
If you want 24V - 0 - 24V you better clarify with Steve @ Apex Jr because I believe he means 12V - 0 - 12V when he says 24V center tap.
FB
mateo88
12-0-12 is what 24v center tapped is. Dual 24v rails are two 24v rails.
@Steve: Do these transformers have dual secondaries "underneath the wrapper" like on many center tapped transformers?
Papageoff
Well that clears up some confusion.
Thanx
Apex Jr
I'll catch up before I go on vacation...
The transformer is set up as a 220 V input and will
deliver 48 Vct and a 24Vct at 7 Amps........
Using 115 Volt as an input you will get 24 Vct
12V - 0 - 12 V and a 12 Vct 6V - 0 - 6V also at 7 amps
as secondarys...Oh.. I should let you know they
weigh 10 lbs each ....... Steve @ Apex Jr.
random_id
two questions:
1. With a transformer like this one, is it possible to combine both secondaries to get a higher voltage (i.e., 12 + 6 = 18)?
2. If not, how does a gainclone sound running off of a 12-0-12 transformer?
Page generated in 0.046767950057983 seconds with 17 queries,
spending 0.00732374 doing MySQL queries and 0.03944421 doing PHP things.
Copyright ©1999-2009 diyAudio.com
