diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
radial capacitors???-info needed - Click HERE for Original Thread
moonshow
hi
what are the pros and cons of radial capacitors, compared with the standard "axial"(is this correct?).
are the radial ones suitable for gainclones?
cause i found a place selling radial nichicon 50v 1000uf. it kinda looks like an oversize resistor.
tnx
hacknet
i thought the standard were radial, and the oversized resistors were axial...?
mcs
Yes, hacknet is correct. You have the two types mixed up. Radial is the type where both leads come out of the same end. Axial are the "big resistor" ones.
Axial caps are not any better or worse than radial caps, so you can use any type. I used axial caps in my amp to keep the boards flat (see here: http://stiftsbogtrykkeriet.dk/~mcs/LM3875/).
Best regards,
Mikkel C. SImonsen
Nuuk
One stands up (radial) and the other(axial) lies down. So it's really just a case of whether you want a flatter but larger layout or a tighter one that is taller. ;)
carlmart
quote:
This thread is getting very sexy! ;) ;) ;)
Nuuk
Right, stop right there Carlos! Franz G will be a long any minute to tell you off. :D
Franz G
Here I am :)
One advantage of radial caps, is: they can be placed very nearby the chip, don't forget this!
Franz
Nuuk
Brazilians Franz! :whazzat: That's all they think about! :D (putting caps close to chips)
Franz G
Don't underestimate Swiss people!
Look my head: no more hair!
Do you know why?
Frontal, I loosed them, because I was too much thinking.
The backside is hairless, caused from a lot of sex.
The complete scalp is getting hairless, when you think just about sex the whole time!
Thats life!
Franz
Ropie
quote:
Franz
From Radial caps to hairless backsides; now that's off topic :D
Just remember axial means 'through' the axis (centre)
Nuuk
Now see what you started Carlos! :bigeyes:
mcs
I would say you can actually place the axial caps closer to the chip.
But I don't think it makes any difference at all...
Best regards,
Mikkel C. Simonsen
carlmart
:) :D :cool: :whazzat:
Getting good!
Page generated in 0.037125110626221 seconds with 17 queries,
spending 0.00820804 doing MySQL queries and 0.02891707 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
