| rs1026 |
Does anyone have To-220-11 library(pcb component) for expresspcb.This is for a lm3886 chip. How to go about creating a pcb component for 3886 chip.Should I look at the data sheet pin distances adn then try to consturct the same by setting grid distances.
Can anyone tell me a simple way to do this. |
| Peter K |
I have made the PCB component (LM3875) myself. I suppose this has the same sizes. You can take it from the attached ExpressPCB file and copy it into your PCB drawing. Hope this helps.
Peter K |
| rs1026 |
| thanks Peter, that will definetly help. |
| pricinosus |
| I design TO220 (11Pins) component for ExpressPCB using National datasheet exact dimensions. |
| jackinnj |
| turn off "snap to grid" which may be set at 25 mils. |
| sivan_and |
rs1026
And don't forget to post the completed PCB pics !! |
| pricinosus |
I attached the file in my previous post but, now i see ... nothing :confused:
I reatach the file |
