diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Polarizers? Oh no... - Click HERE for Original Thread
BigDaddyShoe
Well, there is no going back, I've torn apart my old Fujitsu notebook for an "innovative" LCD projector. I've decided to basically remove the LCD from the casing, and keep it attached to the mainboard section of the notebook by unravelling a quite long DVI? ribbon. It's got an Active Matrix screen, so I don't expect much quality wise, but it's a decent 800x600. I've also got an overhead projector with me which I plan to use to project the image. I've got a small problem, when I took apart the thing, I hastily lost the order of the polarizing sheets behind the screen. I've tried it without these additional (required?) sheets, and get a very pale negative looking image. If I tilt the screen to around 45 degrees to the surface of the projector, I can see an image, but still negative. It's a Sharp LCD if that helps... anyone have any ideas?
TIA
Big G
Duo
I believe those sheets are required as they polarize the light that comes through the lcd to make it work properly. If you take them away, you get a faint negative like you just described, or almost no image at all for a mono lcd...
BigDaddyShoe
hmm... seemed to have figured it out... they're not really polarizers, but thin lenses... unfortunately, if I use them the light intensity is dropped significantly. They do improve image quality though. The projector I'm using is an old-school model that isn't very bright, and does not have consistent light focus, that is, the light is the most intense in the center. I'm getting an image at last without the lenses and without any lights on, and a good screen, but still it lacks a lot of intensity. Wonder if I should go this route or look into the possibility of a standalone contraption (ie all-in-one, not overhead projector). Would probably work out well since the LCD is 12.1" and 800x600. Any thoughts?
Duo
Hmmm, you might want to look into making the school projector more powerful, and try to find ways to increase the eveness of the light somehow...
icculus
you can probably find a new screen for less than 50 bucks at earth lcd or even cheaper on ebay. does, your image look correct if you reassemble the backlight etc.. if not, it's not together right, or youve damaged something.
Page generated in 0.018399953842163 seconds with 16 queries,
spending 0.00529933 doing MySQL queries and 0.01310062 doing PHP things.
Copyright ©1999-2009 diyAudio.com
