| TDA1541A master clock freq, 16MHz ok? - Click HERE for Original Thread |
| deskmate88 |
Hi, most if not all of the clock freq used in TDA1541A systems is the 11MHz clock. However, is it possible to use a 16MHz master clock in a TDA1541A system?
For example, if one would like to use a SONY CD mechanism instead of a Philips one. Assuming I2S signal is made available, but it is an I2S signal from a 16MHz master clock, not 11MHz clock, can TDA1541A take this in directly?
Thx.
DM:xeye: :xeye: :xeye: |
| deskmate88 |
Help! I need somebody help ...
pretty please ...... :bawling: |
| QSerraTico_Tico |
| quote: | Originally posted by deskmate88
deskmate88,
You must be confused as a barking bird.
Use a 16.9344 MHz clock for the Sony transport and 11.2896 MHz for the Philips.
"I2S' from the Sony is NOT the same as I2S from the Philips.
:att'n: |
| rfbrw |
| quote: | Originally posted by QSerraTico_Tico
:att'n:
I'd have to disagree with that. I2S is I2S wherever it comes from. When Sony used the TDA1541A in the past it did not magically become a device that accepted the Sony or Sony/BB format.
Back to the original question. Where exactly on the TDA1541A do you plan to connect system clock? The '41A did away with SCK. Only the '41 has a system clock input. FWIW, read the datasheet for the TDA1541. See the references to System clock, SCK and Bitclock, BCK. SCK = BCK or BCKx2. Max BCK = 6MHz. |
| tube-lover |
dear deskmate88,
pls email to me for the tda1541 & tda1541a data sheet.
hope can help U.
thx
thomas |
| deskmate88 |
"The '41A did away with SCK."
Hi rfbrw,
This is what confuse me. So if I use a Sony KSS213 transport (16MHz clock), then get an I2S output (e.g by format conversion, but no change in clock speed), I can feed it straight to the TDA1541A, right?
thanks
DM |
| rfbrw |
Hi rfbrw,
thanks
DM |
Yes. If the data is oversampled it cannot exceed 4x if it is in the I2S format. |
