| commstech |
I have a Denon DCD S-10II cd player. search all the relevant cd reclocking websites but it seems like there is nothing on clocking this player. I opened up the player and was surprised that it actually has two oscillators, both 16.934Mhz types....one very near to the receiver YM3623 chip and the other one in another area of the board.
I remember reading from one of the threads here that the Sony XA series of players have two of these as well...and there may be some complications in reclocking them, as mentioned by Elso Kwak. Pardon me if i got this wrong.
http://db.audioasylum.com/cgi/m.mpl...ony&r=&session=
http://www.diyaudio.com/forums/show...2946&highlight=
Is it the same case for this Denon player? |
| Extreme_Boky |
Hi Commstech,
I have successfully modified DENON DCD - 1650SR. However, I obtained service manual from DENON Spare Parts first. I suggest you do the same. Send us diagram of digital section of your player and we should be able to help you.
My 1650 uses 4 PCM1704 DACs in dual differential mode, fed by DENON '24/96 upsempler', or how they call it: 'AL24 processing'. There's 16.9344MHz xtal feeding DSP chip, which in turn generates two clock signals. First being 4.2MHz which feeds transport section, and second being 16.9344 feeding 'upsemler' chip. I have replaced the 16.9344 xtal with XO3 clock, fed the main clock signal to DSP chip, and auxiliary clock signal to upsempling chip. The result was excellent!!! However, you have to use very good external power supply for the XO3. This makes big difference.
You should be able to implement XO3 clock (or similar clock with two clock signal outputs) in your CD player. Just remember and pay particular attention to the power supply. Service Manual should not be difficult to obtain, and it will give you directions to all other upgrades possibilities, not only clock!
Extreme_Boky |
| Fabian |
Hi Commstech,
I think the DCD S10 is quite similar to a DCD 3000 my brother once modded.
The clock located near the reciever has no other function than helping it to recognize what sampling frequency is present on the SPDIF input. So there will be no improvement if you change this for a better one.
Just replace the second 16.9344MHz clock that feeds the decoder and alpha processor.
Fabian |
| commstech |
| quote: | Originally posted by Fabian
Hi Commstech,
Fabian |
Thanks Fabian and Extreme_Boky |
| Zero Cool |
I really wished i had kept my DCD-3000, but the rent was due and well.....
I have really liked Denon CD-players, i have had quite a few over the years. I had a DCD-1520 for at least 5 until the laser finally died. then i got the 3000....
What do you guys think of the 3000??? what would you consider to be better in the $400.00 Used price range???
Zero |
| mr l |
| I still own a dcd3000-after 7 years it still sounds fantastic.i doubt i'll find anything better for the price.the difference between the 3000 & the s10 is different op amps used in the filtering section. |
| m127 |
Hi Extreme_Boky,
I have read here that you upgraded a Denon DCD. I have two of them, a DCD-755 and a DCD-1450. I tweaked the 755 with success, and I bought the 1450 non functional, for repairing. The problem should be simple, it's not spinning up the cd so the FOK signal is not there I guess. (The spindle motor is OK). I would need to know how to go to "heat run mode" or "service mode" with the player, thought you may have the service manual for th 1650, and maybe these things do not differ too much. I have a manual for the DCD-2560, but that's totally different so I just don't want to try that on the 1450.
If you have the answers to my questions any help is appreciated.
m127 |
| Extreme_Boky |
Hi m127,
I can e-mail the 1650 service manual to you. It is a bit large - around 12Mb.
Extreme_Boky |
| m127 |
Thank you! That would be a great help! Size is no problem, I have a pretty good email address in Sweden, that can handle large mails. Please send it to: miklos.szaloczy(at)spray.se
Today I've managed to find out how to activate the heat run mode, and it returned with the E1 message, so my 1450 cannot achieve focus. Just as I suspected. |
| Extreme_Boky |
Laser diode is usually turned on by microprocessor chip. This is initialised by tray switch closed (or open). If you measure the correct laser voltage level when the tray is closed and if the spindle motor tries spinning, replace pickup.
Extreme_Boky |
| m127 |
The tray switch is OK. After closing the tray I can see the lens moving up and down trying to achieve focus and then it gives up, so either the pickup is faulty or something is not set correctly (like spindle platter height or so). Unfortunately I don't have an IR meter so I cannot tell if the diode produces the beam.
I tried to send you a mail but didn't manage (the server must be down). I'll try again.
m127 |
| Ruach |
| Hi Extreme_Boky, can you email to me the service manual of the Denon DCD-1650SR? Thanks a million |
| Extreme_Boky |
Hi Ruach,
I have sent detailed circuit diagrams for digital and analog sections. Both are full resolution pdf diagrams with links.
If you really need the full Service Manual, I will have to upload it to ftp server and provide you the link to download, the size of the whole manual is 15MB. Let me know if you need the whole manual...
Nick |
| Ruach |
| Thanks a million Boky |
