diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
my 2x LM3886 in parallel amp finished - Click HERE for Original Thread
alexw88
Just finished :D
More photos and details at http://www.shine7.com/audio/pa100.htm
peranders
Nice work. :up: :nod:
Feel free to join my exclusive :D webring for Gainclones.
http://C.webring.com/hub?ring=gaincloneamplifi
Scott Nixon, if you read this, feel free to join me too. 29000 hits the short time I have had the ring. Free of charge of course.
Guess which web site is the most popular?
demogorgon
looks very good indeed!
good going for someone 16 years old i must say!
(if then the "88" stands for your birth year.. if not, well, still nicely done)
alexw88
16! :bigeyes:
I was 16 years old 16 years ago. :cool:
Sandy H.
I like the layout and thorough job you did with both design and implementation. The pictures and comments are also very helpful. I will use your page as a guide when I am trying to think out the layout of a future project.
Thanks for the post.
Sandy.
peranders
quote:
Originally posted by alexw88
16! :bigeyes:
You are in my webring now. Welcome!
demogorgon
16! :bigeyes:
well, it did look a bit to well made and thought out for somone a year younger than me:rolleyes:
nothing negative intended!
and again: very nice vork:D
btw: i see there is no pot meter, wich implies the notion that this is a power amp. a power amp must have a preamp of course, and so i wonder how you went forward to match the impedans of the power amp with the impedans of the pre amp?
my teatcher did tell me a lite about this thing, i dont rememberwhat he calles the circut :headbash: , but i remember he told me just enough for me to have tons of questions about the subject..
so if you could helt me out, i would realy be grateful!
regards
marius
alexw88
Thanks for your comments :)
I hope my page can be useful for those who want to build a parallel 3886 amp., I won't call it a GC because it uses more components, which voilate the GC concept. However those "extra" components are added for stability and for eliminating all the RF interference.
quote:
Thanks, your webring is very helpful to all the Gaincloners!
quote:
Yes, it is a power amp, and its input impedence is about 47k, which is set by the resistor before the input of 3886. I think 47k is high enough for any pre-amp.
I am using a passive preamp now, so it is actually my DAC driving the amp.
Scribble
Can the schematic on your webpage be modified to accomidate the LM3875 IC?
demogorgon
but when using a fixed resistor of 47k ohms, it's not impedans(Z), it's resistance(R).. Is it the resistor paralelled with a condensator that makes the fixed resistance(R) into impedance (Z)?
I strongly suspect that i should have paid better atension in class..
(Edvard Grieg - Peer Gynt suiten - morgen stemning)
wonderful classical music, really astounding!
alexw88
quote:
Yes, it can be. Just ignore the mute and ground pin as the 3875 does not have those.
Z and R is basically the same thing, with Z is the resistance at a particular frequency.
This link may help you to understand :
http://hyperphysics.phy-astr.gsu.ed...tric/imped.html
Page generated in 0.050687074661255 seconds with 17 queries,
spending 0.01411605 doing MySQL queries and 0.03657103 doing PHP things.
Copyright ©1999-2009 diyAudio.com
