diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Building a High-End computer based DAC - Click HERE for Original Thread
erozsolt
After reading some threads here and at head-fi about DACs using USB interface to get bit-perfect data from computers I decided to open a new topic for building a DAC using these techniques but for a higher-ended level than PCM2702 based USB DAC was.
I think we can concentrate at the digital part first the analogue part could be used from many successful DIY DAC projects. First we have to decide which receiver chip/DAC chip/clock generator to use.
As I read here and on many other sites the only two DAC chips for high-end level (of course for non-oversampling topology) are AD1865N-K (Audio Note DAC1-5 style) and TDA1543 (Kusunoki style). For the USB receiver we can use PCM2707.
The problem is with the different clock frequencies at the I2S interface. In the specifications PCM2707 require 12 MHz clock input whereas AD1865 requires 13.5 MHz and TDA1543 requires 9.2 MHz.
This is the point where I am puzzled now: how to solve the different clock frequencies without making a lot of jitter? Or is it easier to look for another PC receiver (maybe not USB) with a clock frequency other than 12 MHz?
Page generated in 0.013459920883179 seconds with 16 queries,
spending 0.00484896 doing MySQL queries and 0.00861096 doing PHP things.
Copyright ©1999-2009 diyAudio.com
