diyAudio.com diyAudio Forums Archive > Top > Source > Digital
How connect CS8412 to OS filter ? - Click HERE for Original Thread
Bernhard
as I like to play first time with various DAC chips outside CDP as there are TDA1541, PCM56, PCM58 and PCM1702... and in the data sheets signals always have different names, I am lost.
For TDA1541, how can CS8412 be connected to SAA7220 ?
And which OS filter I best use for other DAC chips ?
I have SM 5813 and SM 5841.
In SM5841 data sheet I saw sample/hold used with two PCM58. Why ?
Main problem is that in SM5813 datasheet I see 4 signals input but CS8412 has only 3 signals output.
How do I have to connect CS8412 to SM5813 to use above PCM chips ?
Bernhard
Jocko Homo
Crystal calls them:
MCK, SCK, FSYNC and SDATA.
Don't ask why they make it so hard to understand................
Jocko
rfbrw
CS8412 to SAA7220.
CS8412 OUTPUT FORMAT 2
SDATA => DAAB
FSYNC => WSAB
SCK => CLAB
MCK => XIN
CS8412 to SM5813.
CS8412 OUTPUT FORMAT 5
SM5813 CKDV = HIGH
SM5813 CKSL = LOW
SM5813 COB = HIGH
SDATA => DIN
FSYNC => LRCI
SCK => BCKI
MCK => XTI
Bernhard
Thanx a lot !
arold19
What mean :
OUTPUT FORMAT 2
and
OUTPUT FORMAT 5 ??
Thank
arold19
The FORMAT depend on the Digital Filter chip you are using ??
How you can operate the SC8414 in 2 Format or 5, ?
please
Bernhard
Select with M0 to M3 pins.
Page generated in 0.019623041152954 seconds with 16 queries,
spending 0.00572157 doing MySQL queries and 0.01390147 doing PHP things.
Copyright ©1999-2009 diyAudio.com
