| Crazed_climber |
Would anyone be willing to buy my complete setup? If so for how much?
Heres a list of what you would get.
Sharp qa-1650
(no power supply, but I made I cable to hook up to any computer power supply, vga (you can find the pinout at http://www.diyprojectorcompany.com/) and no remote (select + up or down to change video imputs) and if you still want a power supply then you can go to radio shack and go buy a 12v 2.0A power supply and if thats STILL not good enough for abit more I could go buy you one.)
Diylabs Split Fresnels,
(front one is 13" inches the other one with a blackened out sticker is 8.67".)
Xerox/Fuji 325mm Focal Length Multi-Element Lens
It is suposed to be on of the best Objective Lenses out there. (I had good sucess with it)
EYE LAMP M400SX/BT28/HOR "EYE" Small Envelope.
Specs Are:
400 Watts, BT-28 "EYE" Brand, Small Envelope, Metal Halide, Length 8.307", Diameter 3.543", Kelvin 4200, CRI 65, ANSI M59, Burn Position Horizontal Only, Average Life Hours 20,000, Approximate Initial Lumens 39,000, Approximate Mean Lumens 30,800, Clear.
M59 Standard 400W Multi-Tap, Metal Halide Ballast Kit including a mogul Socket.
Specs Are:
400 Watts, Multi-Tap Metal Halide Ballast, 120/208/240/277 Volts, Lamp Type MH400W, ANSI M59
Any DECENT offer will be considered! |
| superintendent |
I would be interested in the 400w ballast. How much would you sell it for? I am not really sure what they go for. How about 25?
You can email me at andrew01ATgmail.com
AT = @ |
| wylie-c |
| Hmmm..... I would be interested in your MH setup. How much would you want for it if you sold it seperately? ( in CAD ) Also, how big are those fresnels? |
| Crazed_climber |
The lighting system has about an hour use (Im not joking. All I did was test it) and costed me 106Cad so how bout 80? Oh yea and The fresnels are 12.2 Inches by 12.2 Inches if you are intrested.
UPDATE: Someone offered to buy my whole settup besides LCD so I am talking to him, but If it doesn't work out Ill let you have the stuff. |
