diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Optics
frensell ribs - Click HERE for Original Thread
madman01
which way should the ribs face towards the light or towards my lcd
Guy Grotke
Smooth side toward the light source on the lower fresnel. Smooth side toward the objective lens on the upper fresnel. (It doesn't matter if the upper fresnel is right below or 1-2" above the LCD, the ridge-orientation is the same.)
Some LCD panels work better with the upper fresnel below, some better with it above. Depends on the panel's response to non-perpendicular light rays. (like viewing angle) Try it both ways to see which you like better.
madman01
sorry for the late reply thanks
Page generated in 0.014291048049927 seconds with 16 queries,
spending 0.00547338 doing MySQL queries and 0.00881767 doing PHP things.
Copyright ©1999-2009 diyAudio.com
