diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Can the CXD1130 output S/PDIF? - Click HERE for Original Thread
dangus
http://www.diyzone.net/article.php?...order=0&thold=0
According to the babelfish.altavista.com translation, this article is about replacing the CXD1130 DSP chip on a CD player with a CXD1135 in order to enable DOut from pin 27. From that I infer that the CXD1130 wouldn't generate an S/PDIF signal on pin 27 (Dout).
I've been looking for a way to enable digital out on a Laserdisc player with the CXD1130, but I haven't been able to find a datasheet for the CXD1130, let alone the other similar chips (CXD1125, CXD1135, CXD1167). A magazine article claimed that the CXD1130 could do Dout, that it was just a matter of setting the Mode pins correctly. (I already contacted Sony Semiconductor, and they told me that the CXD1130 datasheet was confidential.).
So, can anyone give me some clues here? Thanks in advance.
Elso Kwak
Hi dangus,
Digital out selection (See 10)CXD1125Q, CXD1135Q
When the digital out function is switched to ON, a signal conforming to the Digital Audio Interface Standards is output from DOTX pin. When it is switched to off, WFCK signal is ouput from pin DOTX.
Pin #27 = DOTX
Pin #56 is digital ouput enable. It can be high or low depending on the other mode setting pins. Best check with a scope if you get any SPDIF signal.
:cool:
dangus
Thanks for the reply. To be more specific, the chip is a CXD1130QZ. I know that I tried pulling pin 56 low, and that didn't help. I'll try hooking up all three Mode pins (55, 56, 57) to a jumper block and try all the possible combinations. Do you know if these pins have internal pull-ups or pull-downs?
If I don't get anywhere with enabling the digital output, I'll see if I can feed BCKI/DATA/LRCK (pins 76, 78, 80) to a DIT4096 and get the sound out that way.
Elso Kwak
Hi dangus, As your CXD1130 is not mentioned in the part of text I copied from the combined datasheet I am afraid digital output is NOT available in your case. I don't know about internal pull-down or up. Simply connect the pin to the powersupply OR to ground.
:bawling:
dangus
That would explain why the guy at diyzone.com went to all the trouble of replacing the CXD1130 with a CXD1135. Maybe Pioneer built some versions of the LD-V8000's with the 1125 or 1135, and that's why there is a trace and connector location on the board for the DOUT signal.
I found a few other threads (diyzone, USENET) that mentioned the CXD1130, but none of them gave a definitive answer as to whether it could do S/PDIF out or not.
jonlowe
dangus,
Did you ever get S/PDIF out of your LD-V8000. I am very interested as I am going thru the same thing.
Thanks.
Jon
dangus
No, I haven't tried the DIT4096 yet.
dangus
The CXD1125 datasheet pretty much implies that only the CXD1125Q and CXD1135Q have S/PDIF outs.
Datasheet (mostly in Japanese, but the pinout is in English): http://www.vasiltech.nm.ru/files/CXD1125Q.pdf
There's still some hope for using the DIT4096; I still haven't made a board to use it yet. The CXD1125Q datasheet will be helpful.
Page generated in 0.030968904495239 seconds with 17 queries,
spending 0.00587583 doing MySQL queries and 0.02509308 doing PHP things.
Copyright ©1999-2009 diyAudio.com
