diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Xbox optical to Super DAC 2496? - Click HERE for Original Thread
Whistler
Hi, guys!
First time here for me, and I'm pretty new to the entire hi-fi thingy, so please excuse my lack of knowledge (though I am happy for any tips and further knowledge).
My setup today looks like this:
CD-player: Denon DN-650F
Amplifier: Perception Audio Sansaar
DVD-player, gaming console: Microsoft Xbox
The CD-player is connected via balanced cables to the amp.
The Xbox is connected via analouge RCA.
I recently aquired a M-Audio Super DAC 2496 that I was thinking to use as following:
CD-player via coaxial SPDIF to the Super DAC.
Xbox via optical cable to the Super DAC.
Super DAC to the amp via balanced cables.
The CD-player works great, and the sound is wonderful!
But the xbox-signal is completely ignored: the "Valid Data" LED on the DAC does not light up, and no sound is heard. I tried connecting it to my minidisc player instead of the DAC and it works fine. I get the signal in stereo and it works.
I inquired the official Xbox support (I thought that perhaps it was a bitrate issue) where they gave the answer that they have no information regarding any technical specifications on the console, and that "as long as there is signal in both ends of the cable it should work fine". My reaction to this was the very fine abbreviation "WTF?" :confused:
So hence I turn to you guys. Please help me!
wytco0
I dont know much about this but is that DAC capable of decoding DVD data?
Mikael Abdellah
quote:
I don't think his MD-player will accept DVD-data either so that shouldnt be the problem.
Whistler
Pardon for not saying it earlier, but the Video data is going through a scart-cable with an adapter on it that separate the Audio to the optical cable.
Thus, only audio is signalled through the optical TosLink. The video/DVD-data goes through a separate scart.
rfbrw
quote:
Originally posted by Whistler
<snip>
<snip>
Seems like the Xbox is sending compressed digital data i.e. AC3/DTS to the dac. The PS2 has an option in the on-screen menu for selecting between linear PCM and AC3/DTS data. If the Xbox has something similar, check that PCM data is selected.
Whistler
quote:
Thank you for your reply.
But how can the MiniDisc player play the signal if it is compressed?
Mikael Abdellah
Is there an easy way to analyze the digital data that the optical out transmitts?
rfbrw
That would suggest the data is not compressed. Are you using the Xbox specific connector or the Toslink output? Perhaps it is possible to select the type of data sent to either output.
quote:
Other than connecting it to a player of some kind you would need to either get something a Prismsound DSA1 AES tester or build something around one the newer IEC61937 compliant DAIRs as they are capable of detecting compressed data and signalling its presence without reference to the non-audio data flag. The flags in IEC60958 (aes/spdif) and IEC61937 (ac3/dts/mpeg) datastreams are not always reliable.
wazzup
If you use Xbmc -xboxmediacenter- u can select what kind of output you want from your xbox. It can play dvd`s cd`s and everything else you throw in it, from .mov files to avi.
Your xbox cannot run Xbmc if its not modded though. If you want more info on modding give me an E-mail.
Whistler
I am currently using Xbox Media Player, but perhaps I'll try what you said.
My Xbox is already modded, but I fail to see what that has to do with the digital audio not working through my DAC.
Blue_Max
Whistler,
Have a look in the manual.
If you don't have a copy you can download it from the files section at M-Audio Super DAC 2496 group:
http://groups.yahoo.com/group/M-Audio_SuperDAC_2496
Blue_Max
Do you have two digital sources switched on and connected to the DAC at the same time?
Page generated in 0.038016080856323 seconds with 17 queries,
spending 0.00654483 doing MySQL queries and 0.03147125 doing PHP things.
Copyright ©1999-2009 diyAudio.com
