diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
1.3" Polysi project? - Click HERE for Original Thread
chooch
Hello,
I've searched and haven't been able find many discussions on 1.3" polysi's. Or maybe I just wasn't using a good search string.
Anyways, what do you think of stripping a polysi out of an older commercial projector for a diy project? Parts projectors can be found pretty cheap on ebay.
Is it worthwhile?
Gordon
ancorp
you will need a very expensive controller to be able to connect that lcd to anything. Not worth it. But I would love to see someone build one with such a small lcd...
ancorp
btw, welcome to the forum, its great to have another canadian here :D
chooch
Thanks for the welcome... It's too bad I didn't stumble upon this site earlier. Some neat stuff going on.
What about the board/controllerg from the projector...? I would think most could be salvaged. Especiallly the ones sold as-is because they won't power up. It would probably most likely be just the power supply.
Could a diy polysi projector possibly yield a better result than if the projector was working. Bare in mind that most parts projectors are 3-4 years old.
Gordon
ancorp
well, i dont see the point of taking out everything and building it again..... the only thing I suggest is - if you can get the projector running properly, buy a nice metal hallide bulb of like 400watts, ive seen some for only 20$, and they last 5-10 times more than the original projector bulbs, and cost about 20 times less. You will need a compatable ballast too, about 80-100$. You have to make the projector think that you have a bulb in there. The new bulb will not fit into the projector, most likely. Ull have to make a seperate light box, with a fan, lamp, ballast, and a mirror to bounce the light into the projector. That will yeld much brighter results, at a much lower price than a new bulb. I dont know much about the insides of commercial projectors, so there you go...
Page generated in 0.02187705039978 seconds with 16 queries,
spending 0.00647569 doing MySQL queries and 0.01540136 doing PHP things.
Copyright ©1999-2009 diyAudio.com
