diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
toner transfer method(my mistakes) - Click HERE for Original Thread
rs1026
I tried to build a PCB using toner transfer method and committed two blunders.First of all the design used a opamp and while taking the printout I flipped the image horizontaly.After the PCB was ready I observed that no way I could solder the opamp.Since the image was flipped the pin no 1 of opamp and the PCB did not coincide.
Secondly I coated the pcb with clear lacquer to avoid the oxidation of copper but later only at the time of slodering I came to know that lead did not stick properly on coating of lacquer.
Can someone share their experince on toner transfer method?How to avoid these small mistakes and prevent rework :(
rs1026
I think express PCB has taken the drawing to be SMT mounted by defualt. How can I override this in express PCB?
rs1026
i should not have flipped the image. If and only if SMT is used then I should have flipped the PCB image.
dangus
If they are through-hole components, maybe you can just mount them on the wrong side. Machined-pin style sockets can be soldered at the component side, with care. It helps to include text on the PC board, so you can tell at a glance if it is reversed or not.
I've had mixed success with toner transfer. The paper I use is the biggest variable. However, using an inkjet printer and transparency film (doubled up) and positive photoresist produces much nicer results.
Page generated in 0.019284963607788 seconds with 16 queries,
spending 0.00609255 doing MySQL queries and 0.01319242 doing PHP things.
Copyright ©1999-2009 diyAudio.com
