diyAudio.com diyAudio Forums Archive > Top > Source > Digital
cd104 offset circuit problem - Click HERE for Original Thread
wahee
got loads of problems in my old 104 sorted out. Someone must have spilled water on the servo board-opps
I got the player in a skip, and have been gradually fixing it.
The player will play tracks and the TOC is now working. It skips off after a minute or so though. Looks like the error correction circuit I guess. I can measure the voltage rise on the 6215 ic. I have another cd104 which works fine and the voltage stays fairly steady on the same test.
Anyone had similar problem with their 104 or similar unit
cheers
Page generated in 0.015609979629517 seconds with 16 queries,
spending 0.00788188 doing MySQL queries and 0.00772810 doing PHP things.
