diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
epson 5500c - Click HERE for Original Thread
aclaudio
I have a epson powerlite 5500c the lamp hours indicator reached 2000 hrs and then shut down, I tried to remove the lamp and replace it with a used one and still get the red indicator light for lamp. Quistion is is this unit supposed to power down when the lamp reaches the 2000 hrs or does the unit need a new lamp and houseing can you bypass this process
Neversaid
first of all you should reset the lamp timer aufter replacing the lamp (look into your manual).
Bernhard
aclaudio
This is how the epson 5500c works its internal timer is reset when you replace the lamp with a new one. The lamp houseing has a fu board (short for 100MA FUSE) this fuse is blown when you insert the new lamp assembly and that what resets the internal timer, eprom memory and flash are utilized to store this in the main board. my quistion for some one with experiance with these 5500c models is.
when the lamp timer reaches 2000hrs should the unit power down ?
If the unit does power down should you be able to restart it even if the hours timer has indicated 2000hrs
the reason for my quistions is because I replaced the lamp in the housing only I did not repalace the housing itself, new lamp old houseing, the timer did not reset itself because the houseing was the old one, So I need to know should this unit should power up or do have another problem
ace3000_1
I think you answerd your own question, change the fuse.
Trev:)
chasse
Where did you find your lamp and is it a 150 watt.How did you retrofit the new lamp.
Page generated in 0.02261209487915 seconds with 17 queries,
spending 0.00632238 doing MySQL queries and 0.01628971 doing PHP things.
Copyright ©1999-2009 diyAudio.com
