diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
A good SE project? - Click HERE for Original Thread
icebear
I have been listening to several tubeamps the last week. OTL, p-p EL34 and p-p EL84. To my speakers (Bastani Prometheus) the Edison 24 (with EL84 tubes) was a good match. I'm thinking of building a good SE amp, and wondered if the EL84 also will make a good job in such a construction? There are maybe other tubes that will work even better? I need like 2-3 watt I guess. I would like to get some input on a good projects to work on during the winter. Appriciate som nice suggestions.
Bjørn
Kent Smith
That's interesting.... most people seem to prefer single-ended triodes. But if you prefer pentodes, www.ax84.com looks like a good place. It's more about guitar amps, but I suppose it could work for other things.
mcs
You can see my SE amp here: http://stiftsbogtrykkeriet.dk/~mcs/2A3/
I don't know how good/bad it is compared to other amps, but I like it. I used the parts I did, because those were the parts I could find the day I built it :D
Best regards,
Mikkel C. Simonsen
arnoldc
hi, if you get get hold of the Sound Practices issue that features Gordon Rankin's 807 single-ended pentode, i recommend that. i built one myself and am pretty happy how it drives "commercial (read: 89dB sens)" speakers, like my Infinity Kappa 200. it puts out about 10W of power.
icebear
Hi
It does not have to be pentode. I see that some of the projects connects the pentodes as triodes to avoid 3. harmonic. Any good triode project will also be appreciated.
How about some of these projects?
http://www.bonavolta.ch/hobby/en/audio/el84.htm
Bjørn
arnoldc
then a 2A3, is what i recommend. it's in the range of the power output you're eyeing and can be built relatively cheap and easy too.
Kuei Yang Wang
Konnichiwa,
quote:
Used as pentode the EL84 requires negative feedback on your speakers, but you can get between 3 - 4 Watt. If you use the EL84 as triode (it makes a very nice sounding Triode) you are down to 1.5 Watt or 2 Watts at best.
The way around this would be a EL84^3/5 design, using one EL84 as driver and two or four triode connected EL84 in parallel into 2K4/1K2 output transformers for around 4 or 8 Watt theoretically.
Sayonara
icebear
Interesting. Do you have any spesific schematic for a EL84 as triode?
BTW: Thorsten, you have the prometheus. Do you think 2w is enough?
Bjørn
icebear
http://www.bonavolta.ch/hobby/en/audio/el84_2.htm
No feedback. Good when you don't need power?
bjorn
Page generated in 0.03098201751709 seconds with 17 queries,
spending 0.00999665 doing MySQL queries and 0.02098536 doing PHP things.
