diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Source Follower Enlightenment - Click HERE for Original Thread
SteveS
All,
Would it be OK to use a incandecent light bulb (as in the Zenlightenment amplifier) as a CCS in a source follower configuration? Would it negatively impact the sound? I'm thinking this would be a good way to get around some of the large heatsinking requirements of a Class-A setup.
Thanks,
zagnar
nar
Should be no problem as long as the voltage drop across the bulb is high enough to simulate a real CCS.
Some people here in the forum say that a resistor load always sound better than a real constant current source...
...but in all Alephs the current sources are there,so ...
I'm perplex.What does Nelson state for this crucial point?...
Nelson Pass
The bulbs work just great. Their impedances are fairly
high compared to speakers, and so they don't really
load down the output much at all. See the article for
the appropriate kinds of values and voltages.
SteveS
Will do!
Thanks nar and Mr. Pass.
zagnar
Page generated in 0.019501924514771 seconds with 16 queries,
spending 0.00910950 doing MySQL queries and 0.01039243 doing PHP things.
