diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Please help me check the Aleph Front end PCB Layout - Click HERE for Original Thread
acliao
I incorporated Aleph 60 & Aleph 2 circuits and just finished a rough 2-sided Aleph Front-end PCB ready to be made professionally. Since I am new at this, can the many experienced experts review my circuit layout and let me know if there are any mistakes or anything I overlooked. Thank you very much for your help.
acliao
Here's the sch.
acliao
Here's the PCB Bottom Side with ground grid.
acliao
Here's PCB Top side with ground grid layout.
mpopovics
Hello acliao!
How do you want to make your PCBs?
Do you want to proceed at home, or you will order it from PCB manufacturer.
If you are make it at home, I recommend to use single sided layout. It is much more easier to make it.
The layout itself looks ok. The FETs position have to be checked minimum twice.
Review the high current part, because it seems, the trace width at some point getting not so wide, especially close to source/drain in/out, on top layer.
Are the output resistors fits into small place? Which type you will use?
acliao
Thanks for your comments. I will have the 2-sided PCBs made professionally and am thinking using Caddock for all the output resistors. I'll check the trace width again to make sure they are wide enough.
Page generated in 0.034579992294312 seconds with 16 queries,
spending 0.01136613 doing MySQL queries and 0.02321386 doing PHP things.
