diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
HELP! I Short circuited a IRF9610, now what? - Click HERE for Original Thread
Edwin Dorre
Help!
While fooling around with my Aleph 4, I touched resistor R38 with the cooling element fixed on Q1A1 which gave a big bang... R38 his leg has been blasted in half :-((((
I have changed R38, Q1A2 and Q1A1 and Q2 and Q3 with a new fresh versions, but the amp is still dead. I have no bias whatsoever...
What did I fry? Hopefully not the IRFP240's ...
Enlighted me???
Edwin
Edwin Dorre
I just tested 4 IRFP240's. One random one of first six, one random one of the second six, and the two which had the sense wire fixed to it. All seem to give a good Vgs reading when I test them with the 'matching' method.
Any help is appriciated...
Edwin
Edwin Dorre
Is it very likely for a passive component to blow up? Because I checked a few IRFP240's, changed the IRF9610 and ZTX's for new ones, and still no sign of a bias running through the fet's...
I have the 22ma through the frontend fets, however I do not see 4-5V across the 392 ohm resistor. Also I only have about 2.5V across the Q3 instead of 4-5V .
What can it be?
Edwin
rtirion
I am sorry, to hear your misfortune.
You should test, / swap the zeners. Specially the one on the current source near Q3.
Try and measure the 9..9,2V. If this is not OK swap the zener for a new one. Check the resistors in this CS as well.
Hope this helps a little
Edwin Dorre
Protection zener Z1 and Z7 were blown. I changed them, however still no go. No bias whatsoever... What can be blown also when Z1 and Z7 were blown?
I checked the 220uf's they seem to 'load up' when I solder them out and place them between the ohm meter.
Edwin
wuffwaff
Hello edwin,
since there are not too many parts in the amp I would check every resistor.
If there´s no current going through the 392 ohm resistor maybe it´s broke or a pcb track has been blown, or the value has changed. If you´ve got 22/2mA this always gives 4volt across this resistor!
william
Edwin Dorre
When I run the Vgs match testing way, and I get a normal Vgs of about 4.20V going down when it heats up.
Can I than safely conclude that this mosfet is ok? Or need I an other test to make sure they are ok?
Also, when one mosfet is broken on the current source side what will happen?
And when one mosfet is broken at the amplifier side what will happen?
I swapped boards between my channels, and the working board of the other channel does not give any bias. So it must be the IRFP240's...?
oh, lots of questions...
Edwin
wuffwaff
Hello Edwin,
when you test the fet and it has a normal Vgs at a given current it works!
Did you test all the gate resistors?
Does the other main board work on the other side?
Check all the connections (drive in to each gate resistor, +, - etc.) if the fets and all of the parts are allright either your pcb or some connection must be wrong.
if one mosfet is broken on the current source side it either has 0 ohm or infinite. The first case didn´t happen cause you would have noticed, when the second happens I think you´ll get 2/3 of the current (same for the amplifier side)
william
Edwin Dorre
quote:
Originally posted by wuffwaff
Hello Edwin,
william
I did a quick on circuit test of all gate resistors and the 1.5 ohm resistors. They all seemed ok.
The 'other' board works perfectly on the 'other side'. As both amps did run perfectly before the disaster.
I will desolder all fets to test them all and I am going to breath in and out and then put the 'broken-and-fixed' board in the working side...
I am going to sweat a bit... first of to bed and then tomorrow with a fresh look!
Edwin
nar
If you are not able to locate the error in the amp,then you should repopulate the input board completely.Check out all power mos are OK,and so for the power resistors.Should not be so long,neither high cost problem.
Edwin Dorre
They work again... as it seems, when channel 1 blew, they took with them the irf9610's of channel 2. Also I blew up another pair of 9610's somehow (static electricity?) and the zeners in channel 1 were gone...
Freshs pairs of 9610 in both and I am running!
:-))) me happy!
Edwin
Page generated in 0.033782005310059 seconds with 17 queries,
spending 0.00811648 doing MySQL queries and 0.02566552 doing PHP things.
