diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
New 48" ML-TL Review - Click HERE for Original Thread
abpea
I would like to report my impressions of GM's latest variation of his ML-TL speaker design using the Jordan JX92S. I'll try not to gush or over-embellish. :rolleyes:
All dimensions are internal.
This latest speaker is a 48" triangular cross-section with a 2" port.
When I first listened to these speakers I didn't like them, there was something different about the sound. After several hours of listening and adjusting the stuffing (Acoustistuff) I figured out what was bothering me about the sound.
These speakers go way down low.
I measured the previous versions (original design and trapezoid CS) of the ML-TLs down to ~45Hz. I measured the new 48ers down to ~35Hz. I have never owned speakers that went this low or listened to any that do for any amount of time. The extra 10Hz make a significant difference to the sound IMO.
After getting the stuffing just right (at first they boomed like crazy) I called a few friends over and we settled in for some serious listening. Once again a wide assortment of music was played to help us evaluate the new setup.
At the end of the day everyone agreed the new 48ers were the best of the three ML-TLs built so far. The sound seems richer, warmer and more full. There seems to be 'more' there. I'm convinced I'm hearing more low level information which is adding to or enhancing the sounds I'm hearing but I don't know how to prove it. The 48ers feel more emotional or intimate than the others. A good example was when we were playing Stan Getz's Anniversary cd which was recorded live at the Montmartre Club in Copenhagen. The imaging was holographic and simply spectacular, it felt like we were setting about two tables back from the stage... or maybe it was the wine we were drinking. :xeye:
Another item, GM told me, "... 48" is long enough to get strong pipe action... The tradeoff with a FR driver is it will audibly modulate the mids/HF, so clarity will suffer somewhat."
Maybe we didn't drive them hard enough although those cones were doing a lot of dancing, but none of us could hear any degredation in clarity. In other words everything sounded beautifly clear and natural to our ears. On the other hand we really didn't know what we were listening for other than 'good' sound. :xeye:
There was one weakness everyone agreed on. These speakers (and maybe all FRs in general) are superb listening to acoustic, female/male voice, piano/jazz type of music. But they let you down big time listening to loud hard rock/metal music. The punch of loud rock music just isn't there. Rock/metal music sounded anemic on these speakers. But that's ok cause I don't listen to that much rock anyway. :whazzat:
I recommend this design to anyone interested in building an excellent sounding ML-TL!
(All dimensions internal)
Baffle = 11"
Sides = 7.75"
L = 48.0"
XO = 15.45"
Vent = 2" wide x 2.75" long (center of vent is 4" above bottom)
Stuffing = 0.54lb
Enjoy -
Bruce
abpea
A little more info...
The 48ers seem to be much more sensitive to the amount of stuffing added than previous versions of GM's ML-TLs I've built. I've spent a lot more time tweaking the stuffing on these 48" cabinets than any of the others and the pay-off has been worth it.
The low-end is simply wonderful now. Not 'boomy' at all, more 'bouncy'. Not dull but lively. Pleasantly punchy.
One other thing, and I don't know if I'm having sonic hallucinations or not, but to me piano notes, for example, seem to have much greater sustain than I've ever noticed before. The notes sound rounder, more fuller. Overall this cabinet just seems to have a more pleasing sound.
Standard disclaimer... YMMV.
Bruce
greyhorse
abpea,
Is this GM's improved version you were talking about on the following page? I've been holding back on buying the wood, waiting for it to come out.
http://www.diyaudio.com/forums/show...10&pagenumber=6
abpea
greyhorse,
The thread you reference above is discussing an earlier version, 31" pipe compared to 48" pipe on this latest version.
I have to tell you either one sounds great. The external dimensions for the baffle on the latest version I built is 13"w x 50.25"l which is about 1/3 larger than the cabinet being discussed in the thread you referenced.
If space is a concern go with the smaller one, you won't be sorry.
Bruce
navin
quote:
Does this apply to the smaller 31" line and the trapezoidal line too. Since you have built all 3 lines which of these would sound best in an HT/AV enviroment. I am hoping to use the same system for HT/AV as well as audio.
I feel the box in the center of the "group shot" or the smaller on on it's left would have the best WAF.
abpea
Hello navin,
Yes, same applies to all of the different versions. I think if you want a really big bottom end you're going to end up using a sub in your system for rock music, etc. On the other hand as I mentioned, if you mainly listen to accoustial, live, jazz type of music these speakers will delight you to no end.
The smaller cabinet in the picture is the trapezoidal version. I actually was playing with different ways of mounting that speaker in our tv room to use in our HT setup. And you are right, the smaller one (trapezoidal) has a large WAF. My wife didn't object when we discussed mounting the 'traps' on the wall!! :) :) :)
Bruce
BAM
Just put fabric grilles on them that cover the whole front surface, and impress your friends with your gigantic speakers, and then take the grilles off to reveal the 5" driver.
Bricolo
has this one also been designed by GM?
navin
Yes, same applies to all of the different versions. I think if you want a really big bottom end you're going to end up using a sub.
Bruce
Ofcourse I am planning to use Subs. I was hoping to use subs as low as possible but i might be restricted to the fixed XO freq provided by my HT/AVR (Marantz SR7000). Still slam is not only a factor of subs but also the midbass which would be provided for by the JX92. So what I am asking is that if we Xo the JX92 at say 80-100Hz will there be enough slam? for example if we want to hear the slam of a window/door realistically. While a sub would be moving most of the air the overtones would be reporduced by the JX92.
U read my mind. Wall mounting the JX92 is exactly what I am after. My guess is the small one is about 32" tall and the one in the center is 48". right?
quote:
I am looking for the exact opposite effect.
1. I dont need to impress my friends with gigantic speakers because my big DV12 based subs already do that.
2. I am looking to have speaker that are as small as possible that do not compromise on sound and are affordable (the JX92 is the upper end of affordability but I guess I save some money in XO and tweeter costs). Ideally I would be looking at a speaker that looks like the Bose Acoustimass system but that is more listenable.
chacruz
I'm toying with the idea of building a FR speaker.
Where can I find the drawings for the basic unit so I can apply the mods that are being suggested here?i.e. the triangle, dimm. changes,etc.
Thanks for your help:)
Santiago
ChuckT
Hi, very nice speaker.
A point I would like to know is at what point does the stuff start/end in a MLTL.
BTW, I also have a cab coming for the Jordan. Can't wait.
Timn8ter
It is common practice to start behind and just below the driver and go up.
Dave Jones
My experience is limited to only one example, but I've found that an MLTL is hard to match up with a sub. My little system (FE107E) sounds good without a sub, but for some kinds of music noticeably lacking in bass. With the sub, I managed to get the freq response real flat, but there was something about the sound that was mooshy. I plugged the port on the MLTL's with fiber and raised the crossover point on the sub to match the rolloff of the (now) sealed speakers. It was immediately apparent that it sounded much, much better.
artus
This link previously mentioned: http://melhuish.org/audio/images/press-screw.gif
no longer has this detail. Doe anyone know the how the brace is made? I have read GM's recommendation to include this brace in the construction. Also is felt recommended behind the driver in the trapezoidal and the triangular arrangements, if so, which walls? Thanks
GM
quote:
Interesting! I find them as easy to blend to and can use a lower XO point with more acoustic gain, so I'm curious what all you tried.
See attached. Theoretically the trapezoidal one will need some on the parallel flat back panel and none for the triangular, but as always, best to do your own listening tests. FWIW, I've found that lining the back and one side of the trapezoidal and one side of the triangular has the best balance of damping/acoustic gain.
GM
planet10
Probably more accuratly described as "now aperiodic"
dave
GM
FWIW, somewhere in all these posts or one of the linked threads there are comments from me that 19mm Baltic Birch, Appleply, or no void marine grade plywood be used and Jay Fisher and friend's subjective opinions on how much better it sounds compared to the MDF prototype he built.
Not being a master woodworker, I have never built a speaker using premium hardwoods, but if the wood is stable and with no voids, splits, etc., then they would be an excellent sounding material to use also.
GM
Dave Jones
I'm going to slap a couple of JX92S's in 1/4 cubic foot closed boxes and run them with a sub. The crossover will be around 80Hz. I'll let you know how it comes out. I expect to be every bit as impressed with the results as DIYers usually are. :-)
Annow... back to your regularly scheduled thread.
navin
which sub drivers do you intend to use.
resident
I have done this question to another thread but I'd like to do it again over here.
Are the Jordan (VTL or MLTL) good for 10W tube amp?
Or I need a more efficiency driver?
With what kind of amps are you listening them?
I'm very interested to build them but if they're not so good due to they're low efficiency,I'd like to try something else.
It will be my first FR speaker project.And I'd like to build something that will not disappoint me.
resident
Why is this thread over here and not in fullrange forum? :confused:
GM
There was no fullrange forum at the time this was started and for whatever reason was never moved. I guess the moderators don't have the time to search for/move all the pertinent threads.
Unless you either only listen to chamber music or at very modest average SPL or you just like to hear your amp clip ~constantly, then WRT tube amps, 35W PP is about the minimum I would recommend, with 60-100 being my preference.
The only Jordan system I've auditioned is Jim Griffin's little BRs driven with various relatively high power SS amps in both large and small rooms, so was able to easily find its rather low amplitude audible distortion limits. In either a small room or 'intimate' seating layout though, they will do fine if enough clean power is available.
For only 10W though, I recommend at least 95dB eff. speakers.
GM
resident
:bawling: :bawling: :bawling: :bawling:
pinkmouse
quote:
quote:
Quite right. But it is now!
GM
Thanks!
GM
planet10
Me thinks GM likes to listen loud... i'm using 2 W & 90 dB efficient speakers... every once in a while i wish for a bit more power, but for most of my listening i get away with it...
How much you need depends on, how loud, how big your room, what kind of music.
The low efficiency is my biggest issue with the Jordan...
dave
rcavictim
.......For only 10W though, I recommend at least 95dB eff. speakers.
GM
I have to fully agree with this statement! That is like recommending at least a 105 db efficient speaker for a one watt amp, and this is about right too IMO.
Bricolo
dave
When you say you'd like more power, does this mean that your volume pot it at 100%
planet10
quote:
No... clipping starts at about 50% on the dial.
dave
Bricolo
ok but you clearly hear your amp clip, at the volume you'd like to have
planet10
No at volumes i rarely like to have it at...
But a bit more power would be nice for those occasions... more amps on the way...
dave
Bricolo
more amps... biamping or replacing the amps? ;)
btw, good night everyone. It's 4 AM here
planet10
both... musical amps... musical speakers.. ring around the rosy :)
dave
chrisb
During a recent session at a top secret testing laboratory, attended by Dave D, myself, and several others, comfortable volume levels were measured at the listening position ( approx 3 meters from plane of the speakers)
Drivers were Fostex FE108E Sigmas in Buschhorn MkII enclosures, installed diagonally across a room corner, about 300cm from back wall.
Best guess to net efficiency of the speaker is about 93dB - hard to quantify exactly with a BLH, which like any multi pole radiation pattern derive a significant portion of the total energy at the listening position from boundary reinforcement.
Anyways, quite comfortable listening levels were averaging between 76-82dB ( C weighted)
How much power does that mean I'm using? I don't think at any point in the afternoon did we notice serious clipping issues with 2watts of EL84 triode monoblock power. Theory and the real world are very different places.
purplepeople
The loss at 3m will be about 15dB so the speakers were getting right around 97dB. If you weren't clipping, you must have been pretty close as that's right around 2W at the speaker.
:)ensen.
chrisb
Purple:
I don't have a VOM accurate enough to measure the applied AC to the driver terminals, nor a 'scope to observe the clipped waveforms of test signals, so these observations are about as meatball as you can get:
signal source:
FM interstation noise
1 meter on axis of (single) driver (FE108E Sigma) 70db.
Listening position (actually 2.85 meter) 64 db. The room is only moderately damped, and of course at that distance in spite of the higher frequency directivity that can narrow the listening window for "audiophile grade" soundstage/image etc etc, you're hearing not only both speakers, but the room.
No doubt since FM noise is broad spectrum and the meter is ungated, even at 1M it's picking up a substantial amount of reflected energy. Which was really my point - unless you listen in an anechoic chamber or outdoors, you're gonna hear more than any simple math might predict.
At 70 - 75 db SPL, I know for a fact that my 25wpc P/P EL34 amp doesn't clip, but since the Fostex drivers hav fully broken in the effect with the 2 watt babySETs is so much more musically involving and intimate, that the big amp seems positively brutish by comparison.
There are some things that can be appreciated, but you'll never be able to measure.
Dave:
what new amps are on the way for your system?
planet10
quote:
:)ensen.
6 dB for every doubling of distance... so lets say 9 dB + 82 dB = 91 dB...
dave
planet10
quote:
You know how fast i work :)
XO `1st so i can hook up the subs... got the Don Stenton signature amp for that for now... an allen wright inspred EL84 amp at some point... others in between.
dave
chrisb
So should I clear a spot on my bench?
planet10
Didn't someone ask you about selling your monoblocs?
I'm gathering iron for at least 2 more of those...
Highest in the queue is an RH-84 amp... i have the guinea pig together, it just has a nasty noise i have to track down and then it needs the power supply re-repaired (to clean up after the trouble shooting) -- at this point i suspect a bad filament winding on the power transformer.
Also want to see if i can do a 50EH5 amp with just 3 Rs (+ power supply)... that one is just for fun.
dave
purplepeople
dave
Yeah... I was looking at my response and the arithmetic is all wrong.
:)ensen.
chrisb
Speakers yes, amps no - although I'd be happy to build more of these.
Based on my experience with those recycled power TX, I'd run all heaters except the rectifier on separate filament TX. The high current heater tap for the rectifiers were substantially larger gauge wire - you'd have to work at breaking one, but the filament secondaries for the line level tubes were very flimsy.
At $13 each, the part costs a lot less than the time and aggravation to troubleshoot the problem.
Even at the worst case, the RS 12v 3A centre tapped filament could probably run all the heaters in a monoblock.
planet10
Different trafos, different OPTs... a fresh set of "issues"
dave
Page generated in 0.10398507118225 seconds with 17 queries,
spending 0.00568843 doing MySQL queries and 0.09829664 doing PHP things.
Copyright ©1999-2009 diyAudio.com
