diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph Driver and CCS pcb, anyone interested? - Click HERE for Original Thread
Kari
latley i've noticed that ppl have been asking about if someone has any Driver and CCS pcb's to sell. I'm one of those who needs these also, so i decided to make my own. The design is almost done and i'm going to ship it to the pcb manufacturer pretty soon. While i'm still on this i was wondering if anyone else has these needs? If so, please let me know how many boards you want. I'm placing the order on 15:th of Sep.
My pcb fits 3 fets, can be daisychained and can be used as either driver or ccs and has a size of 100mm x 50mm.
Thx,
Kari
Fuling
Tjena!
Pris?
Kari
Tjena :cool:
If i order 10pcs that would then make it 8USD/pc + postage.
If more is ordered the price goes down....
/Kari
Tazzy
I'm interested in a dual mono pair.
kilowattski
I am interested. Please post an image of your layout.
dobbeln
Hi, I´m also interested.
Please post the schematic and layout.
Kari
Here's a pic of it as it is now. I still might change it a little bit and i need to add a short description.
/Kari
Kari
Well, here's the next version and this will be pretty much it. Please inform me if anyone want to have any boards at the latest on Friday (17:th of Sep).
/Kari
keypunch
Hi Kari,
I just discovered your posting for Aleph PCBs. Hope I have not missed the deadline.
Is this just for the output drivers? Sorry, to me the "driver" board has often in past been referredt to as the input and gain stage circuit. Correct if I am wrong, what you have here is for the output devices only and one still needs the "input/gain" board to complete things?
John L. Males
Willowdale, Ontario
Canada
16 September 2004 01:58
Kari
yes these are for the output devices only. However i just received 7 pcs of "main" boards of which i will use 2. These are prototype boards and as i have said that there might be some issues with it + everything is not marked on the board. If you still are interested let me know. I paid 12USD per "main" board so that will be the price for you too + post.
Thx,
Kari
keypunch
Hi Kari,
Is the only issue for the boards that some things are not marked, i.e. component number, component value; but the boards are otherwise correct?
These are for the Aleph and not the Aleph-X I assume?
Any chance I can see a top and bottom image of them?
John L. Males
Willowdale, Ontario
Canada
16 September 2004 16:34
Kari
Here is the pic of the "main" board. You can use this board for Aleph 2,3,4 and 5. When you decided on which Aleph to build, the only difference between them is a couple of resistors and capacitors and of course the amount of output fets. I can post the BOM if you wan't to.
/Kari
Kari
I have now got the quote for the output pcb's. They will cost 6USD / pc + post. I will order 30 boards of which i keep 4 pcs. Of course all of this is non profit.
The boards have red silkscreen and are goldplated.
Here is a pic of the final pcb layout.
/Kari
keypunch
Hi Kari,
thanks for your reply and posting the pictures of the prototype main boards. I will pass (no pun intended). I have technical implementation reason based on the design shown that be very hard to effect.
Thanks again for takeing time to reply and provide a picture of the boards.
John L. Males
Willowdale, Ontario
Canada
18 September 2004 11:32
Page generated in 0.1351010799408 seconds with 16 queries,
spending 0.08005118 doing MySQL queries and 0.05504990 doing PHP things.
