diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Can someone explain this tranformer? - Click HERE for Original Thread
dvdwmth
I am reposting this from another thread because its important I get this question answered before I carry on with my project.
I had mistakenly been using an over powered transformer in my last project and I'm now building an lm3876 Amp that I need a new power supply for.
I went to the surplus store and spotted a couple of 24V 75VA transformers and figured they'd do the trick.
I've just unpacked them and now I see there are three primary wires :rolleyes: . They are labelled:
120 V 1-------------)
95 V 2-------------)
0 V 3-------------)
the label says
PRI 95/120, 60Hz
SEC 24V, 75VA
So why are there three primaries. Im hoping that this is a supply for EITHER 95V or 120V and that I can just connect the appropriate wire, but I'm not going to assume that.
Can I use this thing or do I have to go buy yet another pair or transformers.
phase_accurate
It is exactly how you assumed: You'll have to connect 3 and 2 for 95 Volts or 3 and 1 vor 120 Valts and you'll be happy !
Charles
BTW: Where, for heaven's sake, is 95 Volts used ?
runebivrin
quote:
On the far end of a really bad power distribution line?
Rune
JojoD818
Your replies make me laugh literally. :D
dvdwmth
Thats a relief.
Im started to collect a bit of a pile of transformers that didn't work out for some reason or another.
I wondered exactly the same thing about the 95V.
phase_accurate
The answer from our friend from the Philipines leads to the assumption that mains voltages below 100 volts are (unintentionally ?) used there.
Charles
Page generated in 0.022233009338379 seconds with 17 queries,
spending 0.00850081 doing MySQL queries and 0.01373219 doing PHP things.
