diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Opamp/DC-Offset Problem (Help!) - Click HERE for Original Thread
MWP
Hi all,
My new DAC+AMP is based around this simple circuit:
The DAC outputs the audio on a 1.6V bias volatge.
The design was meant to use the pot to trim out this voltage on the first opamp.
But no matter what its set to, i always get a -0.7V dc-offset on the OPA627 ouput.
This then leads to a +12V dc-offset on the LM3886's output.
Can anyone see what is wrong here?
I really dont want to put DC blocking caps after the OPA627 to fix this.
Thanks for any help.
Nuuk
Shouldn't that 10K from non-inverting to ground be 180K? :att'n:
analog_sa
Circuit looks fine to me. Are you measuring the voltage at the positive input?
Your speakers will enjoy life close to the edge :)
MWP
quote:
I dont think so.
It wouldnt really make a difference anyway.
The positive input?
analog_sa
Just to make sure that the pot/bias source are correctly connected. The negative input then will have little choice but follow.
Yoghourt
What are supply voltages for your OPA627 and your LM3886?
MWP
So my design is correct then?
If its built correctly (which im 99% sure it is as 4 of these circuits do the same thing) what could it be?
quote:
OPA627 is 12-0-12.
LM3886 is 35-0-35.
MWP
Strange... it needed 2.4V on the OPA627's + pin.
All fixed, can now get ~5mV on the LM3886 output.
Thanks.
drdagor
The op amp bibles say to use a servo to control offset. There are some good notes on designing servos in these notes.
Essentially, provide negative feedback through a low pass filter -- very low pass (like 8 Hz for f0) and it will lock the output of the first stage to ground.
Be sure to use a low noise opamp in the feedback circuit, because you are applying the output to one of the inputs of your gain stage.
drdagor
Page generated in 0.029593944549561 seconds with 17 queries,
spending 0.00815558 doing MySQL queries and 0.02143836 doing PHP things.
