diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
+/- Power supply - Click HERE for Original Thread
Jye
hello,
I have a 24V DC 1A regulated power supply and when I have it hooked up to a bread board with 2 1k resistors in series between the inputs and the middle hooked up to earth I get +\- 12V. But when I connect the rails to the active filter they change to -7V and +14V :bawling: Has this happened to anyone before or does anyone have an idea on what maybe happening?
Cheers
Jye
Bill Fitzpatrick
Did you buy that power supply thinking you would have a good supply for the active filter? Where is the schematic of the filter for us to look at?
Jye
Hi Bill
No, I all ready had the power supply.
The active filter is just the 12 dB/oct Linkwitz-Riley crossover with the buffer stage.
Cheers
Jye
Tim__x
The problem is that your "ground" is a rather high impedance, buffer it with an opamp in unity gain, non-inverting mode.
Page generated in 0.019752025604248 seconds with 17 queries,
spending 0.00785303 doing MySQL queries and 0.01189899 doing PHP things.
