diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Evaluate and critique my pcb design - Click HERE for Original Thread
rs1026
Hi guys,
this is my first try to design a pcb. I am using express pcb to design the pcbs. I have designed a single layer pcb for Rod elliot's 24db roll off Linkwitz-riley filter. Also i have designed a Power supply pcb for the same. Please go through the designs and bring out the flaws in it. I am sure there are lot of scope for improvement. I would be gald if some one points out the corrections.
schematic ,pcb and slik layer of filter and power supply is attached.
(attachment deleted by moderators)
rs1026
power supply pcb and schematic
rs1026
No replies!! someone please reply.
Bill Fitzpatrick
One way I keep my computer virus free is by not downloading zip files from unknowns.
Why not post the appropriate .gif files instead of asking us to mess with a .zip?
ir
just a note about that: assuming you have an anti-virus install like Norton for example, you can simply right-click on the .zip file and select "Scan with Norton Antivirus..." thus making sure the zip is safe to open
rs1026
There are 3 gif files in each of the zip file. So that makes it 6 files. It is difficult to post 6 of them separately. As ir was mentioning u just need to right click and check for sanity in case of any doubt.
Anyway since no one is replying to the post its alright. I will figure out and re work my design myself instead of depending on others.
SY
I couldn't get most of the files, just one pattern that looks like the drilling.
EDIT: :captain: This zip file contains a copyrighted schematic from Rod Elliott. I have deleted it. You're invited to repost your board pattern- you can use a link to Rod's site to view the schematic.
Page generated in 0.153480052948 seconds with 16 queries,
spending 0.12471628 doing MySQL queries and 0.02876377 doing PHP things.
