diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph30 & 60 Schematics and PCB - Click HERE for Original Thread
GeorgeBoles
Dear All,
Exhaustive reading of this board for 3 to 4 weeks and I am only just finalizing thoughts.
1. Is there an official schematic of the Aleph 60 still around. It appears to have gone from Pass's Old Products site ...
2. If I were to build an Aleph 30 or an Aleph 60, which printed circuit boards would you recommend or have individual builders used?
(I have tracked down some very early gifs from one or two people who had just got their PCB design programs up and going, and some were flawed: e.g. input differential pair not mated, narrow tracks for outputs, etc. However it is likely that there are "best" designs out there which I have not tracked down.)
I had also considered using some Aleph 2 boards and making the appropriate front ends up myself, but, in truth, I really am not THAT experienced in design myself.
3. I had considered building the Aleph 30 with P2P as shown by another reader very exquisitely. Without seeing the schematic, would that be reasonable for the Aleph 60 too?
4. I have read that some of the Aleph 30 and 60 projects didn't sound quite as good as their builders expected. Some were silly mistakes (reversal of connections on balanced inputs, wiring errors), but I get the hint that there is a lot more critical matching of components in these amps to get good results than the 2 and 3 series. (In one thread Nelson says: "The input stages of the Aleph 30 and 60 get devices which are matched in the amp itself
by inserting devices until we get what we want." Not knowing what "results" to search for, could that be one of the problems making the Aleph 30 or 60? Of course it is also a reason that lots of people BUY these amps from the "One and Only"
5. Do you get "better bass" from the bigger amps? (My current "lust machine" is the Electrocompaniet ECi4 and its bigger brothers. Wonderful big but tight bass from big loudspeakers, e.g. B&W Nautilus 802 and 803. The ECi3 is no slouch either, but spent much less time with it so not sure if I liked it as much. Problem though is cost of these, hence my time here.)
6. Apart from critical matching of current source and output MOSFETS, are there any other components which should be high on a hit list of "upgrades to audiophile quality". (Maybe this latter question should be saved up to a later day when I KNOW what I am doing. :) )
Hmmm .... that will do for the moment. I am seeing pixels before my eyes and I need something to eat, and perhaps off to the gym to burn off some physical energy. (I have a few questions about "tube friendly" speakers as discussed in the Zen series of articles, but they can wait.)
With thanks for your thoughts, which I hope gel nicely over the weekend.
George Boles
GeorgeBoles
Sorry folks,
Regarding Question 2 of my above post:
I have re-read some of my collection of information ... it looks as if I can pretty easily use the Aleph 2 boards as the basis of an Aleph 30. Especial apologies to Grey R, because it is all quite well outlined in a previous post of his (Aleph 2 boards and others).
However, input into the other questions is still valuable, especially the schematic for the Aleph 60!
George.
PS I would have edited the post, but the edit function had apparently timed out ... oh well.
GeorgeBoles
And now I have the schematic for the Aleph 60. Question 1. now answered. ...
With thanks,
GB
Kari
I have actually designed pcb's for Aleph. You can easily apply it to any Aleph you want to build, depending on which one you want to build, the only difference is a couple of resistors and the amount of ccs and driver mosfets. I should get my boards next week and i most probably will have a couple over. However you need to either p2p the ccs and drivers or design your own pcb for that. Here's the link to the design: http://w1.859.telia.com/~u85937463/aleph.png
I'll post pictures of the pcb as soon as i get it.
/Kari
Nelson Pass
For those of you who didn't catch on, the Aleph 30 and 60
schematics were in the owner's manuals and are on online.
UrSv
If they are indeed still online I think they are possibly a bit hard to find.
jam
Look for Volksamp.;)
UrSv
quote:
That's what I did but failed badly to find anyway...
Kari
Look here: http://www.passlabs.com/downloads/old%20product/
Nelson Pass
That link works fine, but is not on our site menu. Mr. Harrington
is rectifying that now. :cool:
woody
Is he using a soft recovery diode:clown:
Algar_emi
Take a look at my own Aleph30 experience. I did a rather precise schematic at: http://www.diyaudio.com/forums/show...t=&pagenumber=8
Check also my discussion on noise. The gnd layout is very important.
Bye...
SB
zygibajt
Just wondering...
Where do you connect the ground of the diffrential's pair current source?
I found connecting it with each channel's signal ground (besides this one there is only signal ground in each channel) increases the noice.I run it separetly to star ground point.
Bartek
Page generated in 0.066531896591187 seconds with 17 queries,
spending 0.03691101 doing MySQL queries and 0.02962089 doing PHP things.
