| pro |
Hi averybody.
I am planning a power amplifier to couple on the bass section of mine 3 ways loadspeaker.
On the mid-high section Zen V4 works one. Because I have a trafo from 46V 11A, I have thought to an outline very simple one, with the first stage formed from a BOSOZ that directly drives an
array of mosfet in push-pull.
Because I am not expert to make projects, I am asking to you with more experience if this project can work, or if are there some errors.
The amplifier should have approximately 50W with the first 5 in A class, and would work very well under low impedences load.
Any comments?
Thanks to averybody.
Ciao. |
| pro |
Hey, out there.........
No one have to do some comments?
Ciao |
| Nelson Pass |
Is your transformer 46 Volts AC with a center tap? If so,
it will give you maybe +/-30 volts to work with, which is
just great. If it's not center tapped, we have to consider
other alternatives. |
| pro |
Hi Mr Pass.
The 46V is without center tap.
For the input stage I would use a second power supply 55-0-55 80VA.
Ciao. |
| Nelson Pass |
So now you have maybe 60 volts under load. It's probably
easier to select a different amplifier for the transformer or
a different transformer for the amplifier.
Or you could use that 60+ volts to drive BOSOZ. |
| pro |
Because I have already got the transformer, it can be better to change tha amplifier.
But doesn't the BOSOZ works at +-60V?
Ciao. |
| pro |
| And could this one be better? |
| psychosteve |
| the second picture was a bit blurred, any chance of posting a better pic? and can someone please clarify what the power rail conections are, coz im new at designing these things and just follow the drawing. thanks guys, steve.. .. |
