diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
OPA548 and shutdown - Click HERE for Original Thread
kafka
I can't force my OPA548 to shutdown mode. Is's working in inverting mode with gain = 6. As a reference it has tl431 +2.5V. It works as a -15V power supply. But I can't shut it down. I even soldered E/S pin to negative rail and there is still voltage on the output. I've tried with several chips... What's wrong?
kafka
No expirience? No one would help me?
analog_sa
I am not quite sure why you need the regulated reference. As long as the ref is grounded and e/s logic zero with respect to it the shutdown will work.
pinkmouse
I, too, am confused. Could you post a schematic?
kafka
A mistake. It works in noninverting mode. The circut works. I have -15 on the output, but I can't shut it down even then I soldered pin 7 to -20.
analog_sa
I wonder if the problem is not the single negative supply. From the datasheet it seems that polarity should not make a difference but it's still nice to see what's inside the chip.
Are you measuring the output under load?
kafka
No I haven't. But I know I can deliver enough current to make the whole system work. Even a 24V relay :xeye: .
pinkmouse
Have you tried just using the 3 resistor regulator as shown in the datasheet? Just to see if the chip works with the negative rail.
Have you built a positive rail version that works as it is supposed to?
kafka
Positive version works excellant. Chip works with negative rail 'cos at the output I have -15V, as I wanted.
pinkmouse
Hmmm.
Well, If you have two seperate secondaries on your transformer you could just use two +15 versions on dual bridges, that would get you working.
Other than that, drop a line to TI's tech support. When I had a query a couple of years ago they were very helpful.
Page generated in 0.024878025054932 seconds with 16 queries,
spending 0.00843453 doing MySQL queries and 0.01644349 doing PHP things.
