diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Why is 3876 rarely used by folks in this forum? - Click HERE for Original Thread
goering
Hi all,
Topic...
From my observation, and searches in this forum, not very many people here use the LM3876 chip. Is it somehow inferior to its two other brothers, the 3875 and 3886?
I ask because, I am working on a 3876 gc and input from experienced builders will be invaluable.
li_gangyi
i believe it's essentially the same as the 3875 save the mute pin...
rbroer
The LM3876 hasn't been around as long as the LM3875 :cool:
goering
Hi all,
Is the LM3876 ok to use bridged and can it also be used instead of the 3886 in 4-chip BPA config? If so, will there be changes in the components or their values?
Thanks.
Franz G
Maybe you have a look at this application note:
Ouverture Series High Power Solutions
Franz
theChris
3876 isn't used because:
1.) 3875 is easier.
2.) 3886 is more powerful.
if people want the mute, they just go with 3886.
ebijma
Hallo quering,
I asked the same question sometime ago.
They say that the lm3875 sounds better because it has no muting.
I never tested this myself.
Page generated in 0.077559947967529 seconds with 17 queries,
spending 0.06211090 doing MySQL queries and 0.01544905 doing PHP things.
