diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
How to determine optimal bias class A current? - Click HERE for Original Thread
Sunsun22
I've been using resisitor to connect opamp's output stage to -V to achieve Class A operations. Yet, I have the following questions: -
1. How to determine the optimal bias current for different opamps?
2. What will happen if the current is too high?
3. What will happen if the current is too low?
Sunny
arthur
too high bias will generate heat ,or the chip die
too low bias=no use
janneman
The best way to determine it is to look at the expected output current. You want a class A current just above the max expected peak output current, so that the output stage will not cut-off.
Example: Suppose your max output level is 5VRMS which is about 7V peak. Your load impedance is 1K. That means the max output current will be about 7mA. So you should bias the amp in class A say 8mA. With a supply of 15VDC that will need a resistor of just below 500 Ohms.
The dissipation of your opamp now becomes 8mA from the POS supply, say of +15VDC is about 60mW (plus the 'normal' quiescent dissipation, of course, see the data sheet), which should pose no dissipation problems.
Your values may be different, but that's the principle.
Jan Didden
Page generated in 0.025476932525635 seconds with 16 queries,
spending 0.01237488 doing MySQL queries and 0.01310205 doing PHP things.
