diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Battery Supplies - Click HERE for Original Thread
RichardJones
I am using battery supplies on my MOSFET power follower.
2 60Ah 12v SLA per channel.
Do I still need large value caps on the power supply?
Any recommendations for noise reduction etc...?
Thanks!
Jason Hubbard
You should use reservoir capacitors in parallel with the batteries - the current from the batteries relies on a chemical reaction, this inevitably will not be as instantaneous as may be required.
You might want to get some ideas about existing amplifiers notably the hiraga design using this battery/capacitor arrangement from;
http://www.gmweb.btinternet.co.uk/index.htm
Page generated in 0.01931095123291 seconds with 17 queries,
spending 0.00978994 doing MySQL queries and 0.00952101 doing PHP things.
Please support our sponsor.
