diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
How to understand Output voltage gain graphics - Click HERE for Original Thread
screwdriver
I'm trying to make a simple cheap amplifier for my computer sound card and whatever I do I get more puzzled. I would like to make a "decent" amp and when I saw the gain vs frequency graphics I couldn't understand these big differences, could someone explain?
As you can see from the datasheet LM386 and LM384 seem very flat up to 10 kHz, I would qualify this as "good", but what happens with LM 1877? what does it mean a gain that falls linearly?
The puzzle goes on: TDA7265 seems to be beautifully flat at frequencies over 200 Hz, while TDA 2006 and TDA2030 are flat up to a point in tha hundreds of Hz and then fall linearly, again in Gv instead of dB.
Page generated in 0.02129602432251 seconds with 17 queries,
spending 0.00978136 doing MySQL queries and 0.01151466 doing PHP things.
