| LM4780 and 3886 hifi chips? - Click HERE for Original Thread |
| samsagaz |
hey guys, i was looking into the datasheet of lm4780 and lm3886
and i found that the THD in LM4780 is 0.5% and 0.1% into LM3886.
i think that these numbers ar not good enought for an HIFI amp, right?
and another question.. if i use 2 ICs to create an bridged amp, ill get more THD? or will be the same as if i use only 1?
hope ppl understad me :) |
| mikelm |
some amps with .01% can sound really bad
other amps with 2.0% can sound really good
chip amps if done well can sound pretty good
If you bridge you will have twice the voltage available, so it's good for low voltage supplies and /or Higher impedance loads.
If you speaker are 4 - 6ohms bridging will not be ideal. each chip will see 2 - 3 ohms and chips mostly have limited current levels
Why not start with a single chip and see if you like the sound before you try bridging - the sound charactor does not change that much with bridging
hope this helps |
| samsagaz |
ok, so u think that this kind of CHIPs are better than create an AMP using Transistors?
i was looking into my yamaha receiver today and it use 2SC4468 and 2sc1695 Transistors for the amp. |
| tschrama |
| read the datasheet... it seems that at 1Watt both chips perform very similar... THD , at 30W the LM3886 seems a bit better 0.003% v. 0.005 %, but my guess is that the LM3886 and LM4780 are very similar in design and performance... |
| samsagaz |
thanks mikelm
i ll test the 3886 and 4780 after i received it and compare the sound with my yamaha amp. |
