| rs1026 |
I am planning to make a PCb for the circuit given in this Link.
http://sound.westhost.com/project09.htm
I wanted to know if its possible to make a single sided PCb design for this filter. I tried a lot to fit on a single sided PCb but its very difficult.
Can anyone who has tried this help me out?? |
| JensRasmussen |
Hello,
It seems to me that Rod already made a single side PCB for this project. Why not support his design work and simply buy one or two of his PCBs depending on your configuration.
Making your own PCB is satisfying, but there is the risk that you will probably need more than one attempt to get it right and therefore might end up spending a lot of time and effort on making the PCB instead of listening and tweaking the filter.
I suggest you build it on breadboard or get Rods PCB. This will save you a lot of work, and speed up the project.
Good luck
\Jens |
| karahara |
Hi.
I've made single-sided PCBs, but it was not too difficult. I've seperatet in 3 pieces, one buffer and two filter sections.
In a few days i'll make them and then i'll see. :smash:
karahara |
