diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
What problems can happen at high gain? - Click HERE for Original Thread
cpemma
I've a need to boost the voltage gain of a pair of TDA1514A chip amps to cope with the very low output from a portable CD player source.
Datasheet says top limit for the chip is 46dB, which I think is a voltage gain of 200; I reckon I need a voltage gain of about 90 (39dB) instead of the 30 it's currently set to with 20k & 680R.
Are there likely to be any undesired effects just increasing the gain? Should I be adding a pre-amp instead?
Quality hi-fi is not of the essence, the system is in a trailer, driving mid-fi outdoor speakers and running from a generator a few feet away ;)
Mr Evil
Increased gain will give you the following undesirable effects:
  • Increased noise
  • Increased DC offset
  • Increased THD
  • Reduced bandwidth
  • Other things I've forgotten
I doubt you'll have any problems. 39dB is still quite small.
Page generated in 0.027899980545044 seconds with 17 queries,
spending 0.01343083 doing MySQL queries and 0.01446915 doing PHP things.
