diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
100W up to 3000W amp for whitenoise - Click HERE for Original Thread
Simy22
I Need an amplifier at 100W or more, and to be cheap as possible, I dont need it for sound, however I do need an audio amp.
I need whitenoise blasted into a box, in theory it will make the water molecules 'shake appart' now if this works thats great, if it dosnt I dont want to have lost alot of money yaknow?
Ive got the box (which is a half arsed version)
Now heres the specs that I know of:
- It will preferably be mono, I only need one output
- It will preferably be at 100W or more of real power (i dont know all the terms but i know that i need it at min 100W and as high as 2000W is fine (if its somehow cheaper)
- I dont want a filter that I know of, I'm hitting it with white noise, which is basicly that annoying static.
- I need it to ouput at preferably 1.5V or 12V is ok (it can be slightly higher and slightly lower, for the lower 1.2 - 1.8V is fine, and for the 12V quite literally as long as its constant anything will work, but I cant yet handel more then 15V with my setup
- Preferably if this is modular, or someway that I can use it to build a 1000+W system would be nice, although not really required. (if I get the results I expect im going to need more power)
Can anybody help me here? I'm not afraid to build anything (heck I built my white noise generator) I simply need this to be as cheap as humanly possible, and if i get lets say part a which requires a $1000 part B, then part a is still to high, yaknow?
Thanks in advance for your help!
and if sombody has asked a similar question or somthing and i missed it during my 2 hours worth of searching, please excuse me, im not always good with syntax, so could you tell me the syntax you used?
li_gangyi
blast water apart?? like make water mist form in the box?? I belive that can be done with an ultrasonic transducer and a simple driver circuit...but I;m not too sure about what you really hope to achieve...
Simy22
I used blast because, I couldnt spell I had a brain fart, I need it to resonante, to basicly shake the watter molecules appart in an otherwise standard eletrolisys box. I hope to achieve enough gas to run little engines (like a lawnmower) with great efficency, and relativly small size. (although granted not that small)
It also needs to run off of a 12 V system, Idealy the lawnmower will power an alternator or other charging device to power a battery to run this, so im going to assume its the same as a cars eletrical system, which is between 12 and 13.8 right?
I think im going to go with the LM3886 amp chip design thing, But now I'm in the process of finding a DC - DC converter, which will take the 12 VDC in and give me 35- and 35+ DC i think is how it goes, although it seams thats sopposed to be a total of around 70V, but it dosnt make sence to me, why not just say 70VDC? o well...... maybe ill find the answer... any help will be appriceated, as i will post once ive got a plan to have it ran over by sombody with more intelegence then me, so I dont make a mistake...
IT seams the LM3886 (using around 3) will give me around 150 Watts, is this true? and it seams it will cost only around $30-40
also one thing i dont quite get, can the DC to DC converter ment for 3 of these, handel 50?
TIA again!
li_gangyi
try using Class D instead...since u;re not gonna listen to the stuff...I suspect u might wanna find something else rather than a speaker...coz a speaker is not really that efficient (compared to motors and such)
Simy22
Ok Im going to give you guys a hypothetical on how it should work so you can better understand my position.....
First the electrolizer box consists of stainless steel plates (in my super cheap fasion, there actually used stainless steel wall plate covers (with the holes coverd in)) inside a box, which is basicly like a small rectangular fish tank, except the walls arnt made of glass there made of a special plastic, now all the plates are not allowed to touch anything but the walls and water, so eletricity going through them has to pass through the water... the end plates are connected to the output of strong whitenoise generator....
this is so we hit the resonant frequency, the water contains a one of a few chemicals (which i cant remember right now) but they are sopposed to help the water resonante, when that happens they will release more ammounts of 2 H2 and O2, (to be "happy" the atoms need a buddy)
now the box itself is connected to two diffrent things, through some kind of toroid, this part i dont quite understand fully, but from what i can tell it gives the box the whitenoise and 12 volts, this does 2 things, the whitenoise is for resonance only, and the 12 volts is to supply eletrons for normal dc eletrolisys, the later is commonly used today to slowly get hydrogen (its also severly expensive!)
This isnt somthing ive seen work, nor have i built before, i have a few parts however i found the plans online and became intrested in it, i talked to the person who posted them, then to sombody else, yada yada i ended up talking to a reclusive guy who says he discoverd this, but his shop got robbed frequently after he discoverd it.
now im not saying hes right, im not saying hes wrong, i simply want to find out without wasting too much money, there are several uses for the system if it works like he said (like running a car engine, which is a bit premature but if it works its possible) but i first need to know if it works, and find out all the variables yaknow?
Im not driving a speaker, from what i understand the toroid is there for 2 reasons, now please take this from sombody who knows nothing of your field, and try to get through my mindless babbel, the toroid connects the amp, the battery, and the box, it i guess lets the 12 volts go through and forces it to have whitenoise in it? or somthing like that, all i know is i need ATLEAST 100 Watt's MIN, and idealy 1000 Watts, however as this can possible do damage to it, I wont use my friends amp. so i need a cheap solution, and i dont think its coverd under anywarrenty, not like i can afford a $100 store bought amp anways, :(
and if your question still applies, i misunderstood and im sorry, can you rephrase it?
Prune
Sigh...
This is one of those over-unity scams all over again. Tell me this guy's website so I can submit it to crank.net...
You cannot break the laws of physics, try as you may. You cannot get any more energy out of combusting the H2 and O2 that you get out of the water than you put in to dissasociate the water. You are converting from electricity to chemical to heat to work. That has a lot of losses, especially from the last step, and it's more efficient to just do electricity to work -- electric motors.
There have been dozens of these electrolysis schemes, among the thousands of other free energy scams. People never learn. I guess we can blame the state of science education in North America. They ought to teach critical thinking in high schools.
Simy22
I dont care if its not sopposed to work, i want to try it anways, hence keeping it cheap!
I just want my questions answerd ok?
Prune
I see you are from FL. That explains a lot. I spent four years there at USF in Tampa. The sun softened up my brain quite a bit too :hot:
Simy22
Because I'm from florida im going to defend it
::notice the silence yet?:::
and i want to do this because i feel it may work, and if it dosnt i can probibly use everything twords somthing else, i mean it will still be a cheap amp right?
the box wasnt too much, and besides sombody else paid for it:)
back to florida, notice my lack of grammer and spelling? its not for lack of trying (well sometimes capatalizing things IS my fault im just lazy) I personally hold florida, and pinellas county responsible for my lack of literary skills.....
(ohh and BTW: i like your signature!)
Prune
I was just joking about FL. My comment was a result of my dislike of the weather, not the people (in fact my brother lives there, though in Hillsborough, which may be better than Pinellas...).
If quality is not important, then a high powered amp is available for $150 here:
http://lanzar.com/citempage.asp?model=RBVPRO2500
It's a car amp, and I doubt the 1600 W is continuous -- it's probably peak, but that's still a lot. A couple of car batteries or an efficient switching supply should be good to power it.
Simy22
Personally I hate FL, the weather yup I definatly hate that, the people (most of the people down here are just plain ignorant) and the politics, now I know there are stupid people everywhere, but I doubt in such large quantitys, and as far as politics, yeah thats everywhere, and im not getting into that, needless to say i personally think the grass is greaner in cuba!
ok enough about me bashing FL
I was under the impression that the LM3886 based amp circuit will be just fine, and its scalable (which is somthing i like), And I cant buy anything now, unless its for pennies...... literally, im more or less price shopping and trying to find a solution...
So eigther way if i still need the power supply, then I need to tackle that, i still havnt found ANYTHING to help me solve this! and ild prefer to build it on my own anways:) (if reasonably possible)
li_gangyi
a problem with the 3886 is that u'll need to find a suitable transformer or PSU to power it...and it's not gonna be cheap...a class D amp will definetly be more efficient while keeping costs down...
Simy22
I've got the impression youve got somthing in mind! if so, got a link? if not, got a link anways I have seen mentions of class D but no class D themselves, is it an easy, DIY type deal?
the reason i ask is this below scares me:
from http://sound.westhost.com/faq.htm#amp-questions
quote:
Q: As far as I can tell, there is next to nothing on PWM amplifiers at your site, despite the fact that recently there seems to have been some dramatic improvements in chip(set)s that enable truly amazing compact (size of a credit card) amplifiers. I find it curious that you don't seem to have addressed PWM amplification at all.
A: You are correct - there is nothing, and it will stay that way for a while yet.
There are many problems with DIY Class-D amps, and the possible need for surface mount components is only a small part of it. Making/debugging something like that requires considerable expertise in digital signal (or switchmode) analysis, and absolutely requires the use of an oscilloscope. The required parts are also hard to get and relatively expensive, especially in small quantities.
There is nothing curious about it - many people have problems getting a simple discrete amplifier to work, and I don't even want to contemplate the questions I'd get if I had a PWM amp project. I agree that it is interesting, and in a few years most high power amps will be PWM, but at this stage I would be a fool to develop and publish one !
So I ask are you 2 talking about the same thing?
li_gangyi
yes...you'll need a good scope and a signal gen to trouble shoot the thing...but a Car amp is probably class D...so getting one might be a good idea...entirely up to u...
Simy22
im looking at TDA1562
how much is a cheap scope?
Prune
I don't think there is such a thing as a cheap scope that will be useful enough for this kind of work. Certainly more than that car amp. I've seen some DIY scopes, but that's very complex work.
Simy22
Well yaknow maybe i should see if an eletronic shop would let me borrow it, or perhaps a person, i dont know but ill have to figure it out! and chances are i will, but ild need to understand the basics first, lol
Prune
Actually I'm going to bed, as it's 7:30 here and I've been up all night. I don't know anything about class-D/PWM amplifiers, and I've only used an oscilloscope once.
I really don't think you can really DIY cheaper than the car amplifier. You may even be able to use a car battery charger as the power supply.
For a low frequency (to 20 KHz) scope you can use a computer with a sound card and software such as http://polly.phys.msu.su/~zeld/oscill.html
But that's far too low a frequency for PWM and digital work.
Simy22
WAIT!, before you go I've got two broken car charges!, one is mine one isnt (yeah ok so technically i only have one....) it was left outside by a friend..... and it stopped working (gee go figure seeing as its RAINY SEASON! oye) anways, a good number of parts might be fine, if i can use them to get a -/+35V that would be great:)
Prune
Whoa dude, I can reply at a later time...this is a message board, not a chat :)
Post a schematic of the charger.
Simy22
ill see if i can find some info on it, and i sure will post it......
Or i can just start taking components out, and writing down what they are, and then find out what they do, n stuff which i might do:)
Thank you for your help, and the speed at which you gave it:)
Spiro007
Hi I am a newby. excuse my random post, I have two valuable inputs to this thread, Assuming you are still on the white noise topic.
1) when you say white noise do you mean in the audio spectrum? white noise by definition consists of sine waves from 0 Hz to infinity Hz.
It is best to find at least an approximate frequency for the resonant frequency of water, Just a guess but microwaves in the gigahertz will resonate water. and if you want to resonate the individual H or O atoms then the frequency will need to be even higher.
2) If you do manage to get this project working then be very carefull. splitting the oxygen and the hydrogen and keeping them separate until you are ready to combust in the engine is safe. but mixed H2 and O2 fed into the motor will surly back fire all the way back into the container that is storing the gas. I have been there and it is not pretty sight. hehe
Simy22
I dont know exactly how high the whitenoise generator goes, i just know its sopposed to work.
as far as that, there are several easy things to do that will minimize your risk of explosion, and in the case of hydrogen, one heck of an explosion is very easly possible, so i do make sure i take all saftey precautions.
and thanks for your input
raidfibre
Here's how you do it:
Take a glass
Put some water in the glass
Put it in a metal enclosure with an excited magnetron and a metal fan to disperse the microwaves
You have just created steam by utilizing the resonant frequency of water.
If you don't have a metal enclosure with an excited magnetron, ask your mom if you can use her microwave.
Prune
This is a common misconception. Microwaves do not in fact match the resonant frequency of water.
Spiro007
I cannot stop thinking about this one. does any body know the resonant frequency of water Oxygen or Hydrogen??
I have come to the conclusion that for some thing to resonate apart it needs a wieght and a spring and an anchor point(or something of different wieght).
in H2O, the spring is the force holding the O and H. and the wieght needs to be the hydrogen atom and the anchor point is the oxygen. so resonant freq of H would do the job. resonating the oxygen would be very inneficient, becuase the hydrogen molecule would probably just follow the oxygen in phase. also the oxygen would probably resonate too close to the freq of water and would simply create heating of the liquid.
Anybody got anything to add???
By the way microwave oven operate at about 2.45 GHz which is below resonance of water, this is dont so that the wave is not absorbed at the surface of the food, but instead will travel into the food deeper to cook more evenly.
for arguments sake if H2o resonates at 3ghz can anyone work out what would the resonants of H and O would be????
Hint.it should be relative to the wieght of each atom.
sss
there is some other way to make hydrogen out of water isnt it?
li_gangyi
of course...get some HCL preferably concentraed with a bit of water ...and a few iron bits...u'll get Hydrogen out of the mix...
Circlotron
I read somewhere that drawing an electric arc on a piece of aluminium underwater liberates more O & H chemical energy than the electrical input energy because by dissolving some of the aluminium in the process you in addition regain a portion of the energy used to electrolytically refine the aluminium in the first place.
Prune
I don't know about aluminum, but drawing underwater arcs is often done using carbon electrodes, as this produces a gas with various hydrocarbons. A lot of scammers claim this is over unity because burning the gas produces more than input electricity energy, but that's because they ignore that they are using up the electrodes.
Page generated in 0.096132040023804 seconds with 17 queries,
spending 0.00975466 doing MySQL queries and 0.08637738 doing PHP things.
