diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Bypassing DVD amp - Click HERE for Original Thread
Triox
The amplifiers in my Digitrex DVD player which are LM4731,s have been destroyed. These don,t seem to be available in Australia.
These are National 25W /25W.
To cut a long story short , I removed the amplifier chips and heatsinks , put extra sockets on the back of the unit and attached these to what were the inputs of the LM4731.
These inputs are fed by a 1 uF cap and a 1K resistor in series.
I have hooked these new outputs to an external amplifier and all seems well.
Does anyone see any potential problem with this and maybe offer some tips.
I have built some Digi 125s , but am not overly impressed with the sound volume, as my old 35W amplifier seems louder and clearer.
I will probably build some P3A amps or similar and attach
these new outputs to the amp inputs.
My only problem now is I need 6 amps to cover the 5:1 outputs.
I wonder if it,s worthwhile to spend so much buying ready made PCB,s?
ALso do you think I,ll need a pre amp?
Triox
I tried a 741 pre amplifier to drive the digi 125 from my dvd and
it sounds a lot louder, but its a bit noisy, seems to pick up hums and buzzes ,
Any ideas how to make a simple quiet pre-amp?
jaycee
You will probably need a buffer preamp stage because I would guess that the 4731's were being directly driven by the output from the DAC stage.
Do not use the 741 op-amp for audio. It is awful. If you want it simple, build one around an 5532. Elliot's P88 will do if you are into his designs.
Page generated in 0.17298007011414 seconds with 16 queries,
spending 0.13328338 doing MySQL queries and 0.03969669 doing PHP things.
