diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
What's good sensitivity for a car subwoofer? - Click HERE for Original Thread
Datoyminaytah
From what I've read, 88 dB is about average sensitivity for a sub. Is that right? But I've seen subs rated at 92 dB and higher, although for at least one specific model, a forum post I read (not necessarily this forum) said the rating was BS because the manufacturer measured it including "cabin gain". How many others do that, I don't know.
Should I be expecting to find subs with a similar sensitivity to my other car speakers (92 dB,) or is less OK?
Some Kenwoods I just found on ebay are rated between 91 - 93 dB. Any opinions on Kenwood subs?
Volenti
I wouldn't worry about the sensitivity all that much since cabin gain is usually a bigger factor anyway.
The kenwood Excelon range is pretty good, don't get the entry level subs since they have a higher Q and tend to sound boomy.
BillFitzmaurice
Agreed, cabin gain is going to account for a lot in the small confines of a car. so 85-90dB is generally sufficient. The main advantage to higher sensitivity is less distortion, both speaker and amp generated, and horn-loading is the only way to get very high sensitivity. I'll have a horn loaded sub or two suitable for autos appearing on my site over the next few months.
mikee12345
my corner horn F3-40hz horn functioned well in the car,126db with 20watt input at 50hz
Bear in mind the driver was a US$9 8" unit which probably suffered from 10db power compression at its 20w rms rating:dead:
bhg41088
i wanted to design a 50hz folded for a 15" Cerwin Vega Stroker for SPL. would have been fun.
Page generated in 0.023792028427124 seconds with 16 queries,
spending 0.00774026 doing MySQL queries and 0.01605177 doing PHP things.
Please support our sponsor.
