diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
toroidal transformer rating - Click HERE for Original Thread
djdamix
which VA and VAC ratings do you advice me to do à 300W @ 8 ohm audio amp ? The first i've made (thanks to this forum) need 2 x 35V to give about 90w @ 4 ohm. What's the formula to get these parameters ???
I think almost all the loss are in the output state (MOS) ??
UrSv
Too little info. Type of amp (Class A Single-ended, Class A PP, Class AB, Class D etc...). Preferably type/schematic...
djdamix
sorry ... it's class AB output stage, IRFP240 (MOS). I have not the schema yiet ...
David
djdamix
(and of course IRFP9240 also ).... :)
sss
for 300W amp u need about 500VA transformer
djQUAN
quote:
well, I just thought that class A would be out of the choice. 300W RMS with 20% efficiency?
:smash: :D
djk
60-0-60AC will give ±85V no load, 500VA is good for me.
UrSv
quote:
:smash: :D
Hey, asuming too much here. He might be using this in his winter cottage in Greenland where he has his own power plant. Besides, the question is hard to answer if no information is at hand....
MikeW
Check out Rod's subwoofer amp.
http://sound.westhost.com/project68.htm
Page generated in 0.069508075714111 seconds with 17 queries,
spending 0.02835846 doing MySQL queries and 0.04114962 doing PHP things.
