| mitchell |
| i have a sony 250 w amp running a pioneer 700w sub and i want to know if or how i can add another 150 w amp |
| sss |
i guess u want to connect them in bridge mode ,
if so u need 2 identical amps |
| richie00boy |
| Assuming they are either single channel amps (which are usually internally bridged anyway, so prolly not) or a dual voice coil sub. |
| Paradise_Ice |
If your Subwoofer is not a dual coil type, then i would not attempt this.
Just be happy with what you have, more power always means more heat, The Pioneer subwoofers have nice voice coil formers but they can only take a certian amount of heat before failure.
one other thing is, your Pioneer has a Maximium power rating of 800 watts, this is a dynamic rating and not a RMS rating, if you attempt to apply this much power too your subwoofer you will reduce its life span, am talking days even hours, oppsssseee! |
| DilutedImage |
| quote: | Originally posted by theAnonymous1
no |
I couldn't have said it better .. . :D |
| mitchell |
| thanx for your help |
| labjr |
Not exactly !! A mono amp is just that. It's not internally bridged. |
| bigmike216 |
| Not always. Take a look at the of the lower prices, high power amps.. most of them are internaly bridged. |
