diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Post Finished Projectors Here! - Click HERE for Original Thread
cowanrg
I didn't see a thread for ppl to post their completed creations, so I am going to start one. Please, only post pics of your picture quality, and/or projector setup. Only if you are complete, or far along in the stage. It would be cool to see people's setups.
I'll start with mine:
LCD panel: NView Spectra C (modded, see pic)
OHP: Apollo Concept (4K lumen)
Screen: Da-Lite 60" glass bead
I totally dismantled the Spectra C, and mounted it directly to the stage of the OHP. Then, duct-tape around the edges, getting rid of like 70% of light loss. Then, with the space between the LCD and the stage, I used the fans to draw air from the space, and out the vent. works well, never and overhead issue and i've used it in 90F weather for 4 hours straight... (i have no A/C in my house). controller board is attached to back of projector in a make-shift cardboard box. this is just a temporary step.
cowanrg
and the actual picture....
(sorry for the small size, using sony handycam to caputre pictures, it can caputre in 0 light... picture is actually crisper)
SushiMasterX
Please post resident panel resolution also.
See ya at the Symposium! he-he
cowanrg
NView Spectra C, 640x480. I will soon have better pics, once i get my digital camera working.
hemdale99
Hello everyone. This is my first time here so be nice. Since finding this forum I've gotten really interested in building my own projector for big screen fun. I have a question for you, Cowanrg. I just won a Spectra C on ebay. It should be here in a couple of days. I've never used a lcd panel before. Does this panel have a video input or do I need an adapter? If I need an adapter I'd like to order one to be here when the panel arrives. And what kind of controller box system do you have? I already have the Overhead projector so I can't wait to see what my results look like.If they look half as nice as yours I'll be very happy. And I hope this is the appropriate place to ask.
cowanrg
well, for starters, this is totally the wrong place to ask.
but since i started typing, i might as well finish i guess.
the scectra c has its own inputs, which is the DB15 (computer monitor), AND if you get a newer spectra c, or just a spectra, it will have rca input as well. (some ppl may argue with me, but i know what im talking about... some do.)
as far as getting yours to look like mine, well, you need a high lumen projector AND removing it from casing and modifying it like i did helps tremendously. i do not have any other parts than the spectra c and my OHP. you dont need any controller boards, or any additional parts, UNLESS you plan on adding RCA functionality, (if it doesnt already support it). then you need an input box.
but, as im sure from your questions, you haven't yet thoroughly read the forums, i would suggest you do so, and you will find answers to the parts i left out.
gaff
I have an NView Spectra C, and it has a VGA input, a composite (or RCA) input, and an s-video input. All work fine, though I'm sure VGA looks the best.
ldkaplan
Regarding the projected resolution, do you get the 'screen door' effect? I have an old Davis Powerbeam projector that my boss was getting rid of and I notice that a lot...the pixels are blown up so large they are annoying.
Also, are you using the same power supply for both the ohp and the display?
cowanrg
hum, as far as a screen door effect, not really. it depends on the source. if its a dvd, or high quality source, there isnt a screen door effect at all. but, if its a lower source, like an mpeg, or a divx or something, at times, with lower bitrate sources, you get a little pixelation. also, in very very low lighting scenes, there is blockiness. but that is really due to the source combined with low contrast... (commercial projectors have like 1000+:1 contrast ratios. mine, 100:1)
but you see the screen image, and thats at 60" (not diagonally, across). so, if you cant see the pixels there, they dont exist. there was 0 cleanup on that picture.
as far as power supply, OHP's use standard 120V from the wall. they have their own built in supplies for the light, etc... and the panel has an external transformer. i was going to wire them all together for 1 plug/switch, but i decided not to, since this is just my prototype, and ill be messing around more with it later.
but, its perfectly feasible to wire the transformer into the powersupply of the OHP, or vice versa, if you know what you are doing... or just use a powerstrip with a switch on it :-) that works too.
gaff
cowanrg, on your spectra c, does it have a db15 input that says "Optional Monitor" on it? I have tried to hook up my computer to it, and it hasn't worked. Do i need the remote control in order to change inputs?
cowanrg
yeah, i have one of those.
it works for me, i just tested it. the panel has to be on for it to work though... so you gotta keep the panel plugged in for the passthrough to work.
as you can see from my pictures, my IR port is kinda covered, so ive never even used the remote except from the first day, i cleared all settings...
just make sure the panel is on though. (just plugged in)
cowanrg
ok, digital camera is working, and i finally got some pictures.
here are some from toy story 2. enjoy!
another
last but not least.
thelaw
This panel seems great, is the motion smooth and not blurred? I am currently contemplating either this or a Sharp QA-1750 for ahead my newly purchased Elite Vision 4000 (4000 lumens) OHP.
Any input as to which panel i should choose will be greatly appreciated.
thanx
cowanrg
well, i like mine a lot. its the spectra c. other good ones are the z115 i hear, and some of the sharps. other than that, i dont know.
im going to post an mpeg to show what motion looks like on the screen soon! everyone can see what motion blur doesnt look like :-)
thelaw
Yep i think im gonna get this panel. Looks like it renders the color beautifully.
Its the one that looks like this right? :-)
cowanrg
yes, thats mine.
thelaw
is the color really that good on it? or is your camera enhancing it :)
cowanrg
well, the pictures i took are from an OLD fujifilm digital camera. its not a megapixel even... its back when megalpixel was a big deal... so its not super high quality.
the OTHER pictures i took are from a sony handycam... its not a digital, just a hi8mmXR. so, take that for what it's worth... but none of those pictures have touched photoshop. that's what the colors really look like.
i could post a picture of it displaying the 24bit color bar in windows or the pallette in photoshop of anyone wants?
thelaw
That would be interesting, could u take a pic really close to the screen and see if it shows any pixels also? :-)
Im getting this panel when Inventory Solutions find a nice one w/video 4 me.
cheers,
cowanrg
cheers,
sure. up really close you can see pixels, but thats how it works ya know? ill have it up soon.
cowanrg
ok, here you go. up close and personal view of a color pallette.
i couldnt get macro mode to work on my damn camera, so i couldnt get any closer, but just to give you an idea, the color bar is over 1 foot wide. i was holding the camera about 1 foot from the screen or so. so, there's your pixelation! ill try and get macro mode working, so i can get like 2 inches from the thing.
here is the link to the pics, on my site of course.
http://www.diyprojectors.com/galler...creenshots2.htm
thelaw
Well thats just made me want this panel even more :-)
can't wait till i get it
cheers,
cowanrg
in my humble opinion, its the best out there. granted, not that many inputs, only 640x480, but the fact you can get one for $50 or less, its awesome. and its simple. mine is all torn apart, and its the only one that's this simple. i like it.
thelaw
Dreamcast and Playstation @ 60-70". I can't wait :)
Do u use this setup as a normal TV also?
cowanrg
yeah. i have tv inputs on my computer, i have a descrambler with video processor, AND i use dscaler, so i get some CLEAN images at 640x480. ive played dreamcast with it, and it is sweet....
thelaw
how much did u pay 4 yours?
cowanrg
too much. :-) $50 or so is a good price for one.
noodles
I got one for $40 on eBay. Just check there at different times of the day and you might just get lucky. I've never used ubid.com but they might have stuff there also.
cowanrg
nope, ubid doesnt have projection panels.
noodles
They do, but they're hard to find. I saw some Proxima panels on there earlier today.
cowanrg
eh, proximas...
what do they go for, cheap?
noodles
it was around $200 but I checked and it was gone
cowanrg
hum, thats not so good. from what i hear the proximas arent so great.
cowanrg
just a quick note for everyone, i have done some small updates to my site. some good info for newbies, or if you have some stuff to contribute, let me know!
Page generated in 0.059781074523926 seconds with 17 queries,
spending 0.00637984 doing MySQL queries and 0.05340123 doing PHP things.
Copyright ©1999-2009 diyAudio.com
