diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Lighting and OHP
Perfect solution to Heat issues? Halogen especially - Click HERE for Original Thread
ELiTeHaYDeN
While gather parts for my projector, among the list was on 500watt halogen lamp, upon firing it up I was amazed at how much heat it produced, paper would just spontaniously combust when put near it, thats hot! - i knew this was gonna be too much for the LCD to handle for sure, even at distance so I looked for a solution, ive read abit about these IR Reflectors but couldnt find anything locally, so in my search I found out that water absorbs a lot of IR energy, So heres what I tried:
After reading through a few posts, people have mentioned that
water absorbs IR heat etc. So I pondered on this, rocked on down to the local glass place and had two peice of class just larger than my lcd screen cut to size (cost, $6nz about 4$US including glass etc) got some rtv silicon and sealed the two glass plates togeither with as much space as possible, used a seringe to inject water into it and i filled it with water ( bout a 8mm gap between the glass ) ... now this was fine it cut down the heat by atleast half.. but after a while the glass and water became to hot to touch and basically become pointless..
How to solve this? two prongs rtved in, a pump and a small radiator, and a very very quiet fan(inaudable)
this works perfectly! - basically theres no heat on the other side of the glass(this is with a 500watt Halogen), whereas before I couldnt hold my hand anywhere near it. This solution does cut down a little bit of light, my guess would be somewhere in the vicinity of 10% perhaps less.
This is a very viable solution and I will be including it in my design.
What are some peoples comments on this idea? water in the system is one issue yes, however im sure you could make it pretty damn safe, the bulb would really be the only high voltage item in the system, at 240v(here in NZ) and most lcd's run on 12v.. lamp would be above the bottem of the box and sealed in a metal case with a condensor so its not really a issue either.
li_gangyi
u would want to use distilled water and seal the system up so that algae or something doesn't bloom inside...
ace3000_1
Well all i can say is that you have stolen one of my future ideas lol, except mines slightly diff. You will need anti fungal inhibitants aswell as distilled water to cut back mould, corrosion ect.
Ill make mine up soon and show you what i did.
Trev
pinkmouse
:att'n:
SAFETY WARNING!!!
Make sure any system that mixes water and electricity has a Residual (or Earth Loop) Current Circuit Breaker. Dampness and voltage do not mix even slightly...::hot:
li_gangyi
try to use all plastic or silicon tubing and couplers...might not want to see corrosion flowing inside the darn thing...haha...anit-fungal...that's a real cool idea...another way would be to get those liquid that they place inside projection TVs...wun they work good??
quinkin
Is their any optical abberations near the high flow areas?
I thought you may get some rippling if the density changes near the in/out flows were too high.
Q.
li_gangyi
probably reduce the speed of the liquid flow??
ELiTeHaYDeN
it doesnt even need to pump, the syphon effect of the heat transfering through the water is enough so it seems, (heat flowing through the water so to speak) but with the pump on there is no noticable swirls, just need to make sure theres no bubbles and the like, other than that it works just fine
Wes Marquenie
If the lamp give also a lot of UV(c) radiation I wouldn't worry to much for algae or fungi. UVc will kill any micro-organism and they are used in water treatment plants.
ELiTeHaYDeN
bloody good point.
li_gangyi
hmmm looks cool...and seems good in theory...is the "convecion" thingy that "bad" as in enough to move the liquid around the radiator and stuff?? which means the radiator must be below the glass pieces then...
ace3000_1
UV - C kills anything thats bio-organic, thats why it kills your lcd lol, the colour pigments and the polarisers are bio-organic.
Trev
li_gangyi
wouldn't a filter be able to filter that out?? But then...perhaps the hassle involved might put some off using halogens...the cloour too...
ELiTeHaYDeN
theres seems to be very little difference in color, on the projected image from my experience with a Halogen OHP and a commercial LCD projector
Yes, the convection 'thingi' works perfectly, however a little wee very slow pumping pump would be good to make sure its workin as it should.
I dont think UV is just an issue with halogen at all, I thought MH setups actaully produced more UV and IR than halogen? - in which case it doesnt matter which route you take you are going to have to do something about it, however halogen wont be as bad, but it wont be as bright and it will cost you more to run, cause its not as efficient.
Wes Marquenie
If a plasma light source hasn't got an UV-block it will give more uv than halogen. I don't think it produces more ir-radiation becauce plasma is more efficient so less heat, less ir.
I like the idea of natural convection. Maybe include a flow meter which controls a pump. I'm currently working on a class a amplifier completely submerged in sunflower oil in a plexiglass tube and a radiator. It's almost ready for the first test with oil.
ELiTeHaYDeN
The idea about the Amplifier is somewhat interesting but I could probebly save you a great deal of time having had a Watercooled and Phase Change (-25c full load temp) PC.. Oil is not very conductive so to speak it is very hard to pump and the convection idea probebly wont work so well with oil.. Brillant solution to your problem would be a standard Waterblock designed for a CPU and a small radiator and Pump, would be 10 times superior, Im not knocking your idea as I have not tried and I could be wrong, just my view on it
Basically your Amp IC strapped to one of these if you get my drift.
http://www.hard-h2o.com/hardh2o.php...ock-oclabs.html
Water flows through a milled out path in the block.. these happily keep CPU's that put out 100watts of heat at a few degrees above room temperature with a decent radiaitor.
However, this is not the cheapest route, coming in at around $50US for a suitable Waterblock, which may be what your looking for (a cheaper solution)
Wes Marquenie
If the oil heats up a little bit it will probable become more liquid. But I already had in mind to use big tubes (about 1").
Large power transformers are cooled the same way, but there the oil also gives electrical isolation.
ELiTeHaYDeN
yes I believe its a way to conduct heat from the parts of the transformer that are live while maintaining electrical isolation, to the outside fins(where the heat is effectivly removed via air converction).. they generally use a standard type of oil similer to engine oil
Will sure be interesting to see how its turns out, do let us know.
getafix
the worst that could happen, beside possible electricution because of leaks, is that if your pump develop bubbles or, if your not using distilled water, the water calcifies on the glass and tubes/piping.
Wes Marquenie
Indeed, some of them also use an external radiator.
Most transformers use something like shell diala. In some countries they use sunflower/peanut/palm oil. My first plan was to use silicon oil, but it's insanely expensive.
ELiTeHaYDeN
yeah I could only imagine... try purchusing Silicon tubing...:D
dnsey
I once owned a Soviet made shaft-drive motorcycle.
The comprehensive (and rather amusing) manual suggested that if hypoid transmission oil was unavailable, transformer oil would be an acceptable subtitute!
Whether the converse is true, I have no idea...
ELiTeHaYDeN
yeah well as far im aware it still has full lubrication capabilities, its also very thin i think!
ace3000_1
Maybe that explains why the russian car "lada Niva" was so reliable lol, i think you will find they use that oil up there cos its so darn cold.
Trev
getafix
I once saw a car tint that inhibits the passing of IR through a glass pane... the difference with this product as compared to other tints is that it is a transparent tint... looks like plastic. I think the product is SunGuard.
you might want to ask automotive shops about this product.
ELiTeHaYDeN
I couldnt imagine anything that thin and transparent being able to reflect/absorb any helpfull amounts of UV light, but i'll deffinatly have a bit of a scope around on google, thanks.
Wes Marquenie
It won't because light at the low frquency light (red) will be absorbed. This it why 20 or 40 meters under water everything is a little bit more blue/green than it suppose to be.
getafix
me to... but they had this set up where there is a huge lightbulb on one side of a glass pane tinted with this regular and sunguard tint and the difference was very noticeable.
ELiTeHaYDeN
as in the sun gaurd was see through vs the tint?(which the tints purpose is to cut light, and make everything appear somewhat slightly darker depending on the percentage, tints are rated on how much light they allow through, eg "30% tints" allow 30% light through them) or what other difference was there? coloration? (however once again being on car windows, i dont really think you'd be aloud anything that altered colors to a large degree)
getafix
yup the sunguard 'tint' was clear... it somehow blocks of IR or UV rays... i'll try to find the pamphlet that they gave away.
The_Mazta
i love the water idea people, the idea i'm onto at the mo, is a mini fride, there pretty cheap to buy here, and buy using a sealed projector with the components all sealed inside, using the component tubes around the light box will cut the heat down to a minimal, small pipes can also be extended around the inner case to cool that down,
i run a plumbing company so i've got a few of my plumbers on the case,
small fridges are well cheap, and with all components sealed, condensation can be kept out of the areas it doesnt want to be in,
check out my thread with pics of my projector,
check out my thread for my projector
http://www.diyaudio.com/forums/show...&threadid=39818
tesla500
Why not substitute the LCD for one of the pieces of glass? Voila, water cooled LCD! Now you can use this lamp :devilr:
David
Page generated in 0.063363075256348 seconds with 17 queries,
spending 0.00709963 doing MySQL queries and 0.05626345 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
