diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
malfunctioning voltage regulator? - Click HERE for Original Thread
rkc7
I recently assembled a power supply for my active crossover and I used a design from here:
http://ldsg.snippets.org/FILTERS/Pomann/kitsupply.htm
Anyway, the +15 lead reads just under 15V, but the -15 reads -19.5V. I checked over everything, and it seems correct, could this be due to a faulty voltage regulator? The regulators are 7815 and 7915. Thanks.
johnnyx
I would check for a short between the IN and OUT on the 7915. I've had that a few times. The pinout of the 7815 & 7915 are different; if you didn't use the PCB, check that from the data sheets. If there is a reverse - biased diode between IN & OUT , check it's the right way round.
Hope this helps.
peranders
If you are using 79xx, are you aware of that the negative regulator doesn't have the same pinout as the positive 78xx?
moamps
quote:
negative regulator doesn't work properly without any load. Put some resistor (ca 1k) to output and check once again.
Milan
rkc7
Thanks Moamps, I guess it was fine, just needed a load. It's measuring correctly now. And yes, I knew the pin configuration was different, and everything was correct on the board, that's why I was confused. Thanks to all.
Page generated in 0.021105051040649 seconds with 17 queries,
spending 0.00829530 doing MySQL queries and 0.01280975 doing PHP things.
Please support our sponsor.
