diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
resonant amplifier - Click HERE for Original Thread
alecwek
this isnt about amplifiers preamps...or anything...
i need to be able to trigger certain....umm....lets call them events....from my computer...now i dont know annything about programming...or decoding midi messeges...so i was wondering whether it would work if i was using a sign generator...out the sound card..then through several tuned amplifiers to provide triggers to...um...events...
ok lemme put it this way....i play an E on my sign generator....and an F as well....ok so out the soundcard my e and f go....then the signal gets split up and sent to ...
1 a transistor amplifier tuned to amplifiy only the E sine wave....so i get an amplified E sinewave...then this gets sent through some wave bridge rectifiers...some capacitors...and voila u get a steady dc current
2 a transistor amplifier tuned to amplifiy only the Fsine wave....so i get an amplified F sinewave...bla bla bla...
do u see what im getting at...so i can play a sine wave and get this to give a steady dc voltage..that could be used as a trigger voltage for something else...
dyou guys think this aproach would work...also how good...mm..precise are tuned curcuits...will they be able to separate sine waves that are only a few HZ different......
or they extremely difficult to tune precisley and i should just forget about it??.......
Sch3mat1c
http://boss.iele.polsl.gliwice.pl/d...docs/lmc567.pdf
But you can get silent results programming the parallel port in QBasic. Noob stuff. ;)
Tim
alecwek
u gotta be joking...who the heck uses such an ic....welll god bless integrated curcuits....
hey where dyou learn about how to program paralell ports....also the problem will be to make a program...in VSTi to run with my host application...to be able to sequence the ....events...
it would be cool...u could make a cheap drum machine without having to get an expensive midi decoder....or maybe even sequence the flashing of the clubs lights at your next big gig....ahhhhh i love TEKMOLOGY......respect!
but seriously though where dyou learn about this parallel port thing...also how dyou learn to write eprom programs to decode your messeges ...im assuming one would have to do that right??
what language are eproms written in....shiiit it better not be some low level machine code...stuff...holy ****...then ill stick to my primitive tuned curcuitry anyday....
alecwek
no but on second thoughts it wouldnt really work cause the decoded signal triggers a ground connection to be formed at the output...this reall doent help......unless some ones got an idea.......maybe your meant to use it like i have shown in the schematic below....anyone please ...share ur 2cnts...
Sch3mat1c
Geez... for one you don't need machine code because you have QBASIC.. :D High level easy to program language. Get over it, buy the book QB for Dummies and plug away. ;)
No need for decoding because the parallel port has 8 independant outputs; depending on the signal the port is told to output, any one of them can be high or low at any given time. You need decoding if you want more control; you can get up to 256 controls, depending on how you have it set up. Any more and you need two bytes of information (each ON/OFF line is a BIT, 8 of which make a BYTE) and sequential ****, that gets complicated and digital ICs and :eek: stuff...
Google it, it's all over...
Tim
alecwek
wait....can u do that stuff with c++ as well...cause i just started learning...that....yup i now have my very own hello world program:bigeyes:
if u cant then F-it i cant be bothered learning two languages now.....
Page generated in 0.025964021682739 seconds with 17 queries,
spending 0.00836778 doing MySQL queries and 0.01759624 doing PHP things.
Please support our sponsor.
